Hi Guys,
I am shortly relocating from Melbourne to sunny North Avoca on the central coast and would like a few opinions on some options that I have. Some of you will know my car from FCD etc, but for those who don't it is a late 89 red 205 GTI in quite good condition apart from a few little things that are making me evaluate what I should do with it.
Obviously with a move to NSW I will need to get a blue slip when I transfer the rego. There are a couple of minor fixes (such as the washer motor) which will be easy to look after, but the real issues are persistent oil and gearbox leaks. My mechanic down here (Carl at Virage) has looked at it recently and it appears to be leaking from all the way around the sump, and the driveshaft seals are intermittently leaking, usually only when the gearbox oil is at a high level. The car also has a clutch that is getting very tired (not slipping yet), and an very strange gearbox issue/noise that only pops up from time to time. The engine pulls very strongly (67.9kw @ the wheels) but is a little rattly when cold but nothing out of the ordinary.
Now, I know there will be a fair contingent of people who will say sell it and then buy another one up there (particularly when you consider it is not a daily drive), but I am a hopeless romantic for my car so that is not going to happen.
Here are some of my options, and I welcome further suggestions:
1. Take the car off the road once up there and undertake a drivetrain overhaul of sorts. With moving, work etc this would probably take me years to complete.
2. Pressure clean the sump etc and drive straight to the blue slip inspection with fingers crossed.
3. Take it somewhere to get the oil leaks fixed up good and proper and persist with the clutch/gearbox until required.
4. Take the car straight to someone (eg Peter T et al) after I move and go silly on the engine and gearbox, then transfer the rego. Either hot 8v or mi16 are both options.
Money required for any of the above is not really an issue for me, and I do intend on keeping this car for a VERY long time. The decision I know is ultimately mine, but I would love to hear what you guys think.
Thank in advance for your thoughts.
Jim.
