205 S3 Driveshafts
Results 1 to 14 of 14
    SE Melbourne
    49
    Default 205 S3 Driveshafts
    Hi All,
    I need to look into fixing up my S3 205 driveshafts.
    Unfortunately since my car is a daily I can't really afford to have the driveshafts sent out to be refurbished. I'd much prefer to fit in a replacement set myself but these things are so rare they make hens teeth look common.
    I've heard of the UK boys getting brand new GKN driveshafts. Does anybody know how to get these down under? Are there any alternatives?
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    There is a mob down in Hawthorn that reco'd my driveshafts inside of a day if you drop them off in the morning. Good price too ($200 for the pair I think).
    I might be slow... DRTDVL's Avatar
    Auckland
    1,288
    cv from a 405 can be used if you can't find 205 ones, i've got them on my driveshafts.
    7,487
    I've used a GKN driveshaft (from Auto France, now closed) but they aren't nearly as good as an original. Totally different CV joint. 405 or 306 CV joints can be used to reco yours.
    SE Melbourne
    49
    Thanks for the replies.
    Chris, can you please give me the name of the place in Hawthorn that did your drive shafts?
    I guess I could find some 306 or 405 CV joints and fix them up. Then I can take out the drive shafts, put the new joints in and refit all in the same sitting.
    I've never had the privilege to dissassemble a drive shaft before. Is it something that can be easily done by following the Haynes manual or better left to the experienced?
    8V'ville
    919
    Address: 4 Victoria Rd, Hawthorn East, VIC, 3123
    Phone number: (03) 98823242
    That's them I'm 90% sure. I did have their business card but can't find it. Going by the address, I'm sure that's them. They are round the corner from Regans in Hawthorn.
    9,283
    Quote Originally Posted by DjB8V View Post
    A and F Driveshafts.
    You need to find the guy in a good mood to get a good deal.
    Graham
    8V'ville
    919
    I had no problems
    SE Melbourne
    49
    Ok i've decided to get these refurbished by A and F.
    Now to get them out again. I've done this before and I remember it was a bloody nightmare to get the drivers side shaft out. I used a very long pole and got somebody to bash the end while the other was wedged against the drive shaft. Would this be any easier as it was out in the last 10,000km or am I looking at more epic hammering to get it out? Any advice on an easy way to do it?
    8V'ville
    919
    Knock the centre cap out your wheel and undo the hub nut that way. You will need a lot force (breaker ball, even with an extension helps)... Once this is done its pretty smooth sailing after that.
    SE Melbourne
    49
    The hub nut isn't an issue for me. I've got access to an industrial torque wrench. It's about a meter long and with a 35mm socket I get the hub nut off easily.
    I don't think I communicated it properly but I meant removing the shaft from the gearbox end. I've removed driveshafts from BE boxes twice in different cars and every time the drivers side shaft is very stubbornly stuck inside the gearbox. I need to hammer the shaft out using a lot of force.
    Is this just how they are or do they get more stuck in there over time?
    Ie, will it be easier if I have removed the driveshaft 10,000km earlier?
    Fellow Frogger! rtsnoz's Avatar
    288
    Quote Originally Posted by slobberingant View Post
    When I removed mine recently, they had only been in 12months (maybe 30k), and as you said, the drivers side was a pain. I'd be interested if there was a better method of removing than the hammer... I couldn't come up with anything.
    8V'ville
    919
    Not sure what to tell you. Mine came out very easily.
    1000+ Posts djvu205's Avatar
    1,402
    Default shafts
    your better to push them in and give it a good yank out. if this doesnt work there may be a bigger issue, also be carefull when you give tham a good yank as you may lose skinespecially if they decide to come easier than thought.
