205 GTi standard ride height & lowering springs
Results 1 to 25 of 48
Thread: 205 GTi standard ride height & lowering springs
    Jul 2003
    222
    Default 205 GTi standard ride height & lowering springs
    Hi all,
    Does anyone have the measurement on hand (or could measure for me, pref. with photographic evidence) the ride height for the front of a standard 205 GTi?
    Ideally the measurement would be from the center of the wheel arch to the center of the wheel cap / horizontal wheel centerline.
    Background is that my car is a 205 Si with 205 GTi front end, and it is running 'reset' GTi front springs, which I believe are standard springs heated up or chopped, which means the ride height is lower with no increase in spring rate.
    I'm installing Koni sports shocks and now would be an ideal time to upgrade the front springs to something with a slightly higher spring rate, but I want to have a reference for what '30mm lower than standard' (as an example) actually means.
    Examples of springs I'm looking at include:
    Apex - http://www.europerformance.co.uk/pag...sub_category=1
    Eibach - http://www.europerformance.co.uk/pag...sub_category=1
    Cobra - http://www.europerformance.co.uk/pag...sub_category=1
    Avo - http://www.europerformance.co.uk/pag...sub_category=1
    Spax - http://cgi.ebay.ie/Spax-Lowering-Spr...item2a0d03e29f
    Koni - http://www.dcperformance.co.uk/cheap...1020-6106.html
    Finally, any thoughts on the impact on handling of having slightly stiffer springs at7 the front and standard torsion bars at the rear? If anything this would lead to understeer rather than oversteer right?
    Any help appreciated.
    1992 205 Si
    Current: shortened diff (4.4), short shifter, group N top mounts, rebuilt engine and box, solid engine mounts, 1.75" exhaust, strut brace, OMP wheel, GTI suspension & subframe front and rear, lowered 30mm front and rear, solid rear bush, Koni yellows, 306 XT front discs and calipers, ADR compliant braided brake lines, 14" rallye wheels, Dunlop Direzza Z1 Star Spec tyres, immobiliser
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    I have lowered/slightly stiffer springs in the front of my 205GTI with adjustable GAZ struts. It feels really nice.
    If you are in Melbourne, you are more than welcome to come round for a look see.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,370
    Posted this in another section of this forum.
    http://forum.205gtidrivers.com/index...owtopic=120157
    Its a long but interesting read about the geometry and setting up of suspension. If you take the time to visit the sites quoted in the discussion there is some really helpful and simple explanations of how things are effected. Especially when lowering and changing spring/torsion rates.
    Put in short. The 205 is very good standard. Any changes should be throughly thought through. Usually costing a bit to get right.
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    brisbane
    2,899
    30mm is the absolute max you should go before it really starts to change the cars good character IMHO.
    If buying springs you cant go better than the Eibach ones....they suit the car the best but cost a bit more
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    Nov 2003
    Bondi
    3,370
    This page is very tech but an interesting brain strain..... ( for me anyway )
    Cam
    http://forum.205gtidrivers.com/index...=120157&st=100
    91 205 Si
    87 205 GTi Race Car
    Nov 2003
    Bondi
    3,370
    And from personal experience too, I agree with JRs post. Anything more than 30mm and it gets a bit wish wash and unbalanced.
    Ive had Eibachs twice now with koni yellows and they have been great. I did have uprated rear torsion bars to match though....
    Cam
    91 205 Si
    87 205 GTi Race Car
    7,483
    I'm going to disagree. The best front spring to use with the standard rear torsion bars are the standard ones! Set 30mm lower! Here's how it looks, with the rear lowered (320mm c/c) to match.
    Attached Thumbnails Attached Thumbnails 205 GTi standard ride height & lowering springs-minus-30mm.jpg
    Nov 2003
    Bondi
    3,370
    Peter, Would that affect the compressed state of the suspension by not compensating for a reduction in ride height and not upping the spring rate?
    Cam
    91 205 Si
    87 205 GTi Race Car
    7,483
    The spring rate doesn't change, the car just sits lower. Obviously geometry changes (read those excellent articles on the 205 Forum), but otherwise it's the best compromise. People think you need to change the front spring rate. This is totally wrong. The best car I've driven was that red 205 race car I sold to Hans. It had 21mm rear bars, reset standard front springs and revalved red Konis (and a cage). Obviously you can build a better race car with coil overs etc., but it proved how good the original setup was.
    I've driven a friend's standard GTi with just Eibach front springs and it was totally crap. So harsh and unforgiving. My friend asked me to change it back to standard.
    Sep 2005
    32
    I'd have to say the biggest mistake I made with my series 3 205 GTI was lowering and stiffening up the suspension. They were good quality parts(Eibach, Koni) set up by a specialist suspension shop that also did a fair bit of competition work. Sure, it turned in a fraction sharper, but in my opinion the ride was poor and unsettled, it had a tendency to bump steer, and it was diabolical on wet, bumpy roads. For a practical road car to live with on a daily basis that can still eat corners, I'd be leaving it standard(with the possible exception of some of the actual suspension bushes?), and just making sure everything was in tip top shape. Just a thought. Cheers,
    Nigel
    Jul 2003
    222
    Thanks for the responses guys. To Peter T's point about using the stock springs just set lower, this is what I have already BUT I have no idea how much lower than standard they have been set (hence asking for measurements)
    Frankly the car bottoms out pretty easily and the tyres scrub the fenders even going over moderate undulations (partly due to running 185s) hence my opinion that the spring rate is in need of an upgrade / increase. Don't want to turn it into an understeer bucket though.
    1992 205 Si
    Jul 2003
    222
    Peter, to be clear, when you speak of 'resetting' the front springs, exactly how is this done? Heat? Chopping off a coil? Both?
    1992 205 Si
    9,261
    Quote Originally Posted by Langers View Post
    The spring rate would increase if the coil was chopped, so no.
    What's wrong with the standard springs as supplied?
    In the eighties every other car manufacturer was going all out trying to equal what Peugeot had achieved with the GTi, how is anyone not a super smart suspension engineer going to do what they couldn't?
    Have a REALLY good look at the GTI driver article.
    Graham
    Fellow Frogger! spar's Avatar
    sunny coast
    263
    Graham
    not disagreeing, just curious as you kinda didnt answer langers question
    what physical alteration are you mentioning? lowering the bottom spring mount? thats the only thing i can think of that wouldn't change the spring rate.
    if you compress the spring you change the spring rate (well not the overall, but during compression it will be different.)
    if you lower the bottom mount (if possible) then you are hoping that the car hits bumps within x% of its spring rate so that wouldnt work.
    as far as i can work out there can't be any way of lowering a car without changing the spring rates if you want to stop the tyres bottoming out against the arches.
    EDIT: with cars do you just refer to the overall ratio of uncompressed to compressed when you talk of spring rate? rather than the progressive curve?
    7,483
    Resetting the spring is done by heating, then reducing the "free length" measurement of the spring by 30mm. No cutting, etc. The spring is then re-heat treated to retain original hardness. So there is no change in spring rate. The spring rate can only be altered by changing:
    - diameter of wire
    - major diameter of spring
    - no. of active coils
    If the spring had a spring rate of 20N/mm before it will still be the same after. ie A load of 20N will compress the spring 1mm.
    Langers, you said you already have reset springs? If so, what's their history? Do you know who did them?
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    Technically that really should be:
    "The spring rate can only be altered by changing:
    - diameter of wire
    - no. of active coils per a given height"
    This is why sagged coil springs are softer than original while sagged torsion bars are not.
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Jul 2003
    222
    - diameter of wire
    Hi Peter, thanks for that. Not sure who did the spring resetting, but it's Anthony Musson's (Moosey on this site) old Si that Adrian W worked on (at least the box and engine) if that helps?
    1992 205 Si
    NSW
    627
    They are reset standard 205 gti springs.
    Why don't you just put the correct size tyres on the car, ie the same as what was on it, and stop messing with it. It handled really well before. just look at Anthonys lap times.
    Adrian Wuillemin
    Jul 2003
    222
    Quote Originally Posted by Adrian Wuillemi View Post
    Hi Adrian,
    That's a nice idea in theory, and it was my starting point as well, but unfortunately you can't actually get sticky rubber (whether R compound or near R compound) in 175s anymore. I tried every specialist tyre stockist in Sydney and 2 in QLD but no luck.
    Even the 185s I had to order from the US - people just don't have cars with 14" wheels anymore!
    For the record for anyone in the same situation as me (with 14" wheels), these are the choices available in 175s:
    http://www.tirerack.com/tires/TireSe...&x=-423&y=-443
    and a much better choice in 185s:
    http://www.tirerack.com/tires/TireSe...4&x=-517&y=-84
    I ended up with the Dunlop Star Specs.
    1992 205 Si
    7,483
    Quote Originally Posted by davemcbean View Post
    - diameter of wire
    I've never seen height/length in any formula for spring rate.
    http://www.engineersedge.com/spring_tension_calc_k.htm
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    sunny coast
    263
    thanks peter
    springs are progressive in the force required to compress them, so when you reset them does it evenly change the rates over the spring movement? or does it remove the soft initial part?
    or can this be altered by where you heat and how you reset them?
    mine has magic reset springs afaik and it feels like the initial softness has gone, which i'm fine with cause car seats are infnitely softer than a motorbike and i like the way it feels.
    9,261
    I can see that if the colis were flatter there would be more leverage on them, giving a softer spring rate the question would this be significant?
    Graham
    Jul 2003
    222
    Quote Originally Posted by pgti6 View Post
    Yup. Bear in mind though that those are proper R compounds, which means they won't handle heat cycles associated with day to day driving very well. The Star Specs I ended up with are designed to handle the heat cycles, provide loads of grip and not fall apart on the track.
    1992 205 Si
    NSW
    627
    so rather than buy another set of rims and put r specs on one and street tyres on the other you stuff around with a proven setup before you even get it on the track and see how it handles.
    What you spend on springs would be far more than another set of steel rims.
    I can't follow your logic.........
    Adrian Wuillemin
