407 with a leaking boot
    Dec 2010
    1
    Default 407 with a leaking boot
    Hey guys,
    I'm just new to the forum and I am hoping you can shed a little light on my problem.
    I've got an 05 407 HDI sedan and with all of the heavy rain lately I've disovered that a serious amount of water has been collecting in the spare wheel well under the boot...
    I've obviously cleaned it all up and now park under cover where possible but does anyone know where this leak might be coming from?
    Cheers, Pugalug.
    5,312
    Icon10 Helpful.
    Bonjour Pugalug,
    L'eau tombe du ciel, une force majeure.
    Mike.
    Started out with nothing, still got most of it left.
    Sep 2003
    North Parramatta
    3,997
    Hi Pugalug,
    Welcome to
    It's possibly a boot seal that's damaged or a rear light assy that's not sitting properly or has a damaged seal.
    The other alternative, depending on how much water you've been driving through, is that a plug in the wheel well has come loose.
    If you're game, you could get someone to lock you in the boot while they direct the hose at it. You may find the culprit...
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Fellow Frogger! Meggsy's Avatar
    351
    Does the car have a tow bar... After I had mine fitted and lots of rain here in Brizvegas I found the slack shits that had done the installation failed to refit the gromet correctly that the harness for the tow bar and the rear parking sensors passed thru going from inside the car to thae outside ... hence 2 incjhes of water in the boot with lots of rusty Iron filings left over from the installation
    Good luck
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    I have never had any problems with water in the boot personally. The boot lip is pretty high considering.
    Also check the rear lights are not letting water in and that the foam backing is properly attached. If its not pushed over all the bits sticking out from the back of the light, the light can sit unevenly.
    FYI don't over tighten the plastic nuts? holding the light on as they are a bugger to get off it over tightened!!
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
