406 FAP Questions
Results 1 to 9 of 9
    Dec 2010
    WA
    45
    Default 406 FAP Questions
    406 D9 ST HDi 2.0 Wagon 4sp Auto - built 2002/11
    Hope you don't mind some newby FAP questions:
    • Handbook says a 2 Litre HDi with automatic gearbox has a particulate emission filter. But does it really?
    • If it does have a FAP, where is it and how can it be recognised as such? NOTE: The bulge in the exhaust pipe between engine and silencer is completely smooth, doesn't have a heat shield and doesn't seem to have any wires connected to it.
    • If it does have a FAP, where is the Eolys tank?
    Looking forward to some enlightening answers!
    Dec 2010
    WA
    45
    Default RHZ versus RHS
    Am I correct in presuming that "RHZ" in the VIN means "HDi 2.0 80kW without FAP" and "RHS" means "HDi 2.0 79kW with FAP"?
    Albury
    154
    Quote Originally Posted by Ymer View Post
    FAPs were first used on the 307 range, in 2005 (or maybe late in 2004) with the new series engines, the 1.6L 80kw and the 2.0L 100kw HDi. Well, that's in Australia.
    11,014
    I don't know for sure, but I'd expect that your VIN number holds the answer - maybe start with the dealer. Have you asked whoever services the car?
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    London, UK
    294
    If the car has a FAP then the large bulge (which is both a cat and and a FAP) will have two temperature probes and two pipes comong off of it that lead to a pressure differential sensor.
    If it doesn't then it's a simple cat and not a FAP.
    I thought that on the 406 only the 2.2 HDI has a FAP, but my knowledge is limited to Euro spec cars.
    Dec 2010
    WA
    45
    Default FAP-less
    Quote Originally Posted by dieselnutjob View Post
    If the car has a FAP then the large bulge (which is both a cat and and a FAP) will have two temperature probes and two pipes comong off of it that lead to a pressure differential sensor. If it doesn't then it's a simple cat and not a FAP.
    Thanks for confirming. Definitely FAP-less. Not sure why the handbook mentions a PEF (particulate emission filter)..
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,869
    Top tip - If you want to see the specification of your car, join Peugeot ServiceBox and plug in your VIN!
    2005 Renault Clio 182 Cup
    Dec 2010
    WA
    45
    Default Peugeot Service Box
    Quote Originally Posted by STALLED View Post
    Thanks. Great Resource: http://public.servicebox.peugeot.com
    And good for the French vocabulary, e.g. "plaque de police".
    London, UK
    294
    Because it's the same handbook that covers the 2.2 HDI which does have a FAP.
