Changing 206 XT cambelt
    Dec 2005
    Rockhampton Queensland
    10
    Default Changing 206 XT cambelt
    Are special tools needed to change the cambelt on a 2001 206 XT 1.6l 16v or can it be completed by a competent mechanical workshop? Thanks in anticipation.
    Troppo Frog
    1996 Peugeot 306 XT
    2001 Peugeot 206 XT
    1951 Citroen Light 15
    Fellow Frogger! chez00's Avatar
    567
    I've never done one but there are very few timing belts that a competent mechanical workshop can't do. To make sure I'd try to get my hands on the workshop manual and have a peruse through the procedure, and if unsure pass it on to your mechanic. Often "special tool 18" is not that special, but is a relatively common tool like a twin cam gear locker or a 3 legged puller etc that any competent mechanic would have.
    Hope this helps.
    Dec 2005
    10
    Thanks for that. Gives me confidence. In the interim I have tracked down a workshop manual that covers the 16v engine so I will take that along and have a chat to the mechanic. Only lists a couple of locating pegs and a belt clip as special tools.
    Troppo Frog
    1996 Peugeot 306 XT
    2001 Peugeot 206 XT
    Aug 2003
    NIMBIN
    33
    Troppo
    Where did you get the manual that covers the DOHC engine ?
    NIMBIN
    Dec 2005
    10
    NIMBIN
    As a CD on ebay from the UK. Same ebay listing as below but a different seller name. Paid A$10.50 plus postage. Covers 206/306/406. What is on the CD takes a bit of unraveling but I found the TU5J4 motor on it. Does not appear to be a complete repair manual but it had what I wanted on the cambelt.
    http://cgi.ebay.com.au/PEUGEOT-206-4...item3363cfec56
    Troppo
    Troppo Frog
    1996 Peugeot 306 XT
    2001 Peugeot 206 XT
    Aug 2003
    NIMBIN
    33
    Thanks troppo
    As a matter of interest I cheated today & pulled a 1.6 DOHC engine out of a spare car I have lying around (have Four others on road).
    Once you have the engine out the timing belt change is relatively easy.
    Found a few little tricks that will make life easier when doing it in vehicle.
    Contact me if you have any dramas.
    Regards
    NIMBIN
