306 XR Headlights
Results 1 to 7 of 7
    Dec 2010
    Australia
    8
    Default 306 XR Headlights
    Hi Iwas wondering if anyone has encountered same problem of no low beam lights but full high beam on 1995 306XR. Is this only a globe problem Thanks
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,335
    G'day i'm not sure myself but I'd start with the globes then the switch. If it's neither of them check the fuses and relays!
    Cheers Chris
    Dec 2010
    Australia
    8
    Default 306 XR headlights
    Hi Thanks so much for your reply. I will work through your suggestions
    Fellow Frogger! paulrb's Avatar
    Dec 2004
    Geelong
    214
    Default 306 lights
    I'd checks the switch...... it is very unlikely that both globes with blow at the same time... I think they are wired separately (or at least on separate fuses) to at least keep one going if the other blows... Although I could be wrong on the 306....
    306 indicator stalks are known to have problems with grime getting into them and shorting them out. In particular the relay goes off even when the lights are off..
    I have had this problem in both the '94 and '01 versions of the 306 I have cleaned the stalk out by hand and solved in in both cases.
    I would think that your problem might be in the high beam switch. You might find it is cancelling out your low beam at all time, not just when switching up to high.
    Remove the indicator stalk and give it a good clean out with some goop remover and when dried plug it back in. Even if this doesn't solve your head light problem it will help with the reliability of the indicators etc in the future.... and it is a simple job....
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by paulrb View Post
    If they are both fitted at the same time originally, why not?
    My 306 had both globes fail at the same time. More commonly, most people won't notice one blown until the other blows or someone points it out to them.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Dec 2010
    Australia
    8
    Quote Originally Posted by SLC206 View Post
    Thank you for this information will check all out
    Dec 2010
    Australia
    8
    Quote Originally Posted by tmodel View Post
    Hi finally had problem solved. Both low beam globes had failed. Told it could benn as result on their age that this problem could have happened. My thanks to all who offered help in forum
