306 s16 pink slip advice - engine mounts!!
Results 1 to 8 of 8
    Dec 2010
    10
    Default 306 s16 pink slip advice - engine mounts!!
    I've gotta get my 306 s16 pink slipped (NSW) next week, and I'm just worried I'm not gonna pass! The car seems to have the common 306 loose engine mount problem and the driver's window regulator is also broken, so the window won't go down! Are these failable offences?
    Does anyone know of a list of what they check for with a pink slip so I could get everything ready?? And maybe even a sensible and reasonable mechanic somewhere around the north shore??
    Oct 2003
    canberra
    856
    Default 306
    have you tried changing the driver side window switch with the passenger side?
    top engine mount is easy to see reasonably easy to change
    Dec 2010
    10
    It's not the switch, it's the regulator - it's swallowed the cable!
    Top is easy, does that mean bottom is impossible??
    Oct 2003
    canberra
    856
    Default 306
    Bottom mount is difficult as it has to be pressed in !
    top mount is bolt on from memory
    Sep 2003
    North Parramatta
    3,997
    Mounts are not impossible, no.
    P504 Services at Waitara and PQ Automotive at Chatswood are both good independent Peugeot mechanics in the North Shore area.
    I'm sure there are others.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    64
    I was failed for having a non-working window recently.
    Sydney - Chatswood
    2,023
    I've never seen them check a window during any of my pink slips. Often they just do the brake test and don't even bother checking the lights.
    Patrick
    Architect
    1991 Peugeot 605SVE (Written off 2007)
    1995 Peugeot 605SV (Bianca White) *SOLD*
    2007 Volvo XC70 Electric Silver (PJ-810)
    2009 Volvo XC60 T6 Teknik (Sapphire Black)
    2014 Volvo XC70 Luxury D5 Polestar (Ice White)
    2012 Mercedes Benz C250 (Alabandite)
    Past:
    1974 Triumph 2000Mk2, 1990 Renault 25TXE, 1986 Rover SD1, 1990 Peugeot 605SV, 1991 Peugeot 605SVE, 2001 Volvo XC70 and various Volvo 200-series
    64
    Suppose it depends where you go
