1999 306, Clock display very very dim
Results 1 to 8 of 8
    S.E Melbourne
    190
    Default 1999 306, Clock display very very dim
    Hi guys.
    I just noticed that the clock and temperature display in my 306 has gone very very dim. For example when I have my sunglasses on it just looks all black, if you get real close to it you can make out the numbers.
    What could be the problem?
    Thank you
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    388
    Quote Originally Posted by nomis View Post
    Hi guys.
    Thank you
    A blown globe
    cheers Pete
    I am gunna get another 403 on the road........one day
    Sep 2003
    North Parramatta
    3,997
    It's a simple fix. You unclip the fascia around the clock (use a flat bladed something) then two torx screws hold the clock in.
    On the back of the clock are two square plastic things that you turn a quarter turn to reveal two bulbs. Replace these blown bulbs with new ones (I think they are 1.2W T5 or something similar - just take the globe to REPCO, Burson, SuperCheap, etc.) and refitting is a reversal of the removal procedure (sic).
    That should fix things considerably.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Fellow Frogger! michaelh's Avatar
    Apr 2001
    157
    Are your sunglasses polarised? Have you tried sans sunglasses?
    Current:
    1973 504GL Berline
    1997 406 ST
    Past:
    R19RT; 1979 504GL Berline with Factory Air; S3 205GTi; 206GTi; 505STi; R4
    Fellow Frogger! cme2c's Avatar
    235
    Be careful that the globes are correctly aligned in the holders. Its easy to misalign them and the new globe doesn't work.
    Also, be aware that polarised sunglasses make some displays impossible to see.
    John
    206 GTi 2003
    VW Golf 118TSI 2009 ( the wife's)
    Bedford CF 1980
    Valiant VJ Ranger 1974
    "Driving a 206GTi makes you feel like you're 18" Jeremy Clarkson
    S.E Melbourne
    190
    Quote Originally Posted by SLC206 View Post
    Awesome man thanks a lot, will check it out.
    Regarding the sunglasses comments, I shoulda made it more clear in my original post that the problem still occurs when I am not wearing sunglasses :p!!!
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,260
    Default It's NOT the globes!
    When did you last see your Optometrist?
    Over the summer break I've got to pull the Foulcan's dash to bits to replace 3 or 4 blown globes. I've got no problem but SWMBO gives me grief regarding the instrument/dash not being as "reliable as her Honda Jazz!" There is a ten year age difference in 'her' favour!
    Also her's has done 92K and mine 280K with the obvious % of night/dark driving!
    At least your's straight forward.
    Fellow Frogger! matt_molon's Avatar
    Dec 2010
    SYDney
    192
    had the same problem with my 306. just carefully remove the clock its not too difficult. check the globes arnt blown and take them to an auto one and they will replace em cost u like $5 absolute max and then put it all back together. with the temp gauge im having the same prob also the climate control light is dim. i really dont want to have to dismantle the console or dash and risk snapping a crucial piece of plastic and subsequently have a loose fitting dash.
    happy pugging
    2004 206 GTI 180 BLACK
    1998 406 2.0L auto ST WHITE
    [email][email protected][email]
