tyre fitment for 1993 205 si?
Results 1 to 10 of 10
    Brisbane, Australia
    70
    Default tyre fitment for 1993 205 si?
    so it looks like i can get a set of citroen c5 15x6 alloy steelies and some tyres for real cheap
    but im not sure if the tyres will fit
    they're 185/65/R15.. wondering if they'd fit a 205 SI with standard springs
    thanks guys
    Brisbane, Australia
    70
    anyone?
    48
    No, you would need to go to a lower profile tyre, common sizing for the gti being 195/50/15. On my Si, I'm thinking of trying to find some 185/50/15 tyres when I put on my 15's.
    Melbourne Australia
    1,382
    Hi I have 4x Yokohama C Drives for sale - 185 x 55 x 15 - less than 500k's - $75 each - Melbourne
    Jul 2003
    222
    Bear in mind that the Si has different rear arch shape to GTi. Leart that the hard way.
    1992 205 Si
    Current: shortened diff (4.4), short shifter, group N top mounts, rebuilt engine and box, solid engine mounts, 1.75" exhaust, strut brace, OMP wheel, GTI suspension & subframe front and rear, lowered 30mm front and rear, solid rear bush, Koni yellows, 306 XT front discs and calipers, ADR compliant braided brake lines, 14" rallye wheels, Dunlop Direzza Z1 Star Spec tyres, immobiliser
    9,258
    Quote Originally Posted by Langers View Post
    What size did you try to fit?
    Has anyone modified their Si wheel arches?
    I reckon I will have the same problem.
    Graham
    48
    I test fitted one of my cyclone rims which had a 195/55/15 tyre on the rear of my Si and seemed like it should fit without rubbing but I didn't drive anywhere though.
    9,258
    Quote Originally Posted by 205tim View Post
    Thanks Tim, I've 195 60 14s on the back of mine at the moment, not rubbing on the wheel arches.
    Graham
    Aug 2005
    Liverpool NSW
    317
    the widest recommended tyre for a 15x6" wheel is 195. i have seen C5 steelies fitted with 205 wide track tyres but this size is uncommon in 15". the nominal size for pug 205 15" wheels is 185/55 though 195/50 is commonly used due to price & availability + it won't put your speedo out too much.
    with the C5 steelies, check that the wheel bolts have a tapered end rather than a flat end... AFAIK, there was a recall on the latter due to the wheels cracking near the bolt holes.
    Andrew.
    C2 VT​S
    205 GTi
    1000+ Posts djvu205's Avatar
    1,402
    Default c5 rims on si
    they fit on the back nicely but stick out past the guards on the front by about 1/2"
    i think there is 50mm difference between front and rear track on the si. the front being wider.
