405 headlight issues
    Jan 2006
    North West Tas
    46
    Default 405 headlight issues
    I'm sure I'll be able to fix it but I'm hoping someone can cut my fault finding time down a bit.
    Last night when I turned my headlights on, everything was fine until I put them on high beam where I noticed a slight glow in my left hand dashboard indicator arrow. The front and side indicators are also dimly glowing.
    When I dip them back to low beam I think (not sure as it was raining) one of my right high beams may be staying on and the left headlight looks to be a bit dull. I need to turn them off and on very quickly to put things right. They always turn on, on low beam.
    I'm assuming an earth problem with the left front headlight or possibly a high beam relay issue.
    Any help appreciated, thanks.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    Default Crook earthing
    Quote Originally Posted by FBvisitor View Post
    Sorry that this will sound silly, remove the back passenger tail light connection accessed via the boot and clean/check the connections.
    Good luck
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Jan 2006
    North West Tas
    46
    Thanks, and its not as silly as it sounds as I've had water ingress through both tail lights in the past.
    Will check it out sometime today hopefully.
    Cheers.
    Jan 2006
    North West Tas
    46
    Problem solved. Thanks BIGRR. Correct diagnosis.
    I've seen far far worse tail light contact tabs and bulb connections happily still working but a quick scratch up with a screw driver and wipe with a rag and we're all good again. Finnicky french electrics coming to the fore maybe.
    Thanks.
