Mi16 power steering pump
Results 1 to 15 of 15
    1,376
    Default Mi16 power steering pump
    Does anyone know if you can get a a kit to rebuild a Mi16 power steering pump? I thought I had a leaking rocker cover gasket but it's the pump that's spewing out fluid.
    Many thanks
    Moo
    Don't remind me!
    16,609
    I'd be positive you can.
    At the same time, I'd also be positive you could get a darned good result on overhaul at a fair price from David Hill.
    It seems hard (as a mug punter) to source some types of kits; you can find things on sites like Alibaba but then you look and the minimum purchase is 100 units or some similarly inconvenient amount.
    Australia
    123
    Sorry to inform you Addo but i am getting out of the power steering side to concentrate on the race cars-Gould GR55B,Force PC & Mallock 32B also the 2CV resto.
    Sorry-but previous work still ok for warranty.
    Don't remind me!
    16,609
    That's a shame (for selfish types like me). I don't like Mr Rack's attitude, and am not so comfy with his product.
    1,376
    Default Surprise surprise
    I was able to get a kit to put through my power steering pump. Cost me $20.00. Looks like a universal kit that does all pumps with certain years.
    There is some paper that comes with the kit. I will take it to work tomorrow, scan it and post it for all to see.
    1,376
    Default Pump Details
    I Have attached details for the kit. pdf docs below.
    Attached Files Attached Files
    Australia
    123
    That is an American Saginaw pump,one of the best and cheapest to repair,if the cam ring is worn(look for chatter marks-grooves,also wear at largest diameter-feel edge with your finger-i can supply new ring at a good price).
    As i told Addo i am getting out of the power steering and will have all Citroen-Peugeot-Renault parts for sale,
    Feb 2001
    Romsey, Victoria, Australia
    4,869
    Quote Originally Posted by 2CV David View Post
    We find that pumps are quite reliable, we hardly sell any and hardly get any calls on them (2CV David) might disagree but I think you'd be very unlucky to get 2 leaking pumps so a good second hand unit might work.
    We have lots of them, like I said, we hardly get any enquiries.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Australia
    123
    If you want to kill a pump run it low on oil,if rebuilding only use a high temp seal kit.
    1,376
    Hi David (both), Initially I thought I had a leaking rocker cover gasket. Over the weekend whilst changing the stater and a coolant hose I now see it is the PS Pump leaking, thus buying the kit.
    Also I noticed the ram is not in good (clean) nick. Will I be able to buy a kit for that too or is that part more involved.? I think I have a spare Mi16 one but not sure if it's the same size. (just haven't checked it side by side yet)
    Australia
    123
    Only some rams are easily repairable(ones where the seal is retained by a circlip,i have the seal for series 2 Xantia and XM,cannot remember the shaft size offhand but will advise tomorrow.
    1,376
    ok Thanks David.
    Australia
    123
    Ram seal size as promised last night.
    23.4mmx37.8mmx5.5mm.(genuine citroen) $15 each including postage.
    1,376
    Oh that's great. PM me some bank details and I'll transfer you some money and delivery details.
    Thanks David. Just to confirm it will be the same as a 92 205 gt S2
    Australia
    123
    Before you rush in and send me money measure the shaft diameter and confirm that you can remove the seal,i do not know the size or spec of the 205 ram.
