307 front indicator globe replacement
    111
    Default 307 front indicator globe replacement
    Hi all,
    The front drivers side indicator globe has decided to blow so I now need to replace this.
    Any idea what sort of globe I need and how the hell do you get access to the globe from under the bonnet?
    Looking at it briefly last night, looks like I have to remove the black plastic cover over the washer bottle. Does that then provide easy access or will I have to be a contortionist to get my hand in there?
    Sam.
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by sgt_doofey View Post
    Hi all,
    Sam.
    Have a look in your owner's manual. It should explain how to do this and what globe to purchase.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Fellow Frogger! PeugeotRob's Avatar
    Southern Highlands NSW
    149
    Hi all,
    Sam.
    Sam,
    Whilst I can only 'ditto' Simon's reply regarding the globe replacement, I can advise that the black plastic cover which fits over the radiator expansion tank is easy to remove and replace. There are two small plastic lugs....just press in the centre of said lugs and they will lift up, allowing the black plastic cover to be lifted out of the way. To replace the lugs, push the centre section up half way, replace in the locating holes and push back down so that the centre section is flush.
    Rob
    2007 Peugeot 307 XSE
    ____________________________________________
    Previous Peugeots: 1995 306 XT, 1997 306 XT
    111
    Thanks guys.
    I haven't had a chance to check things out more closely, hence posting on here as I had hoped to get the opportunity to purchase a globe on my way home tonight to replace it when I get home. I only noticed it last night and only had the opportunity to lift the bonnet to see what the situation was whilst waiting for a friend to come out of her house. I was hoping to get more of people's personal experience than anything.
    I'll be setting time aside tonight to look at things more closely, including the manual.
    Sam.
