505 GTi question ......
    ade
    ade is offline
    Jul 2003
    154
    Default 505 GTi question ......
    I have just fitted a new head gasket on the 505 GTi and and up to the point of putting the ancillaries back on when I noticed a hole on the upper side of the water pump (see pic). I have not placed coolant in yet but it would appear to cause a leak. There is a rough surface at the outside and appears to be a spigot has broken off. However the Haynes manual indicates there IS a hole in this location.
    What is this hole for/from? Was there spigot there that has broken?
    Last edited by ade; 13th November 2010 at 03:22 PM. Reason: insert pics ..... properly
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Re-attach pics as thumbnails, they have not come through as full pics????
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    1000+ Posts okalford's Avatar
    Sep 2004
    10,959
    Hi ade, I just took a photo of mine for you and if I am guessing the right part, mine has a hole there too. I also put a little piece of wire inside and it will hook under sideways as though it could leak ie the hole is vertical and to some degree horizontal; at its depth, if that makes sense.
    Mine does not leak there, it is an '89 505 GTi, petrol, manual.
    On mine there does not seem to be any broken off rough surface though.
    ETA If you want any more photos or info to compare let me know.
    Attached Thumbnails Attached Thumbnails 505 GTi question ......-water-pump-505gti-diag.jpg
    '66 404 Wagon
    '78 504 Wagon
    '89 505 GTI S II Familiale
    Dec 2002
    Menzies Creek
    2,541
    That hole is on the outside of the seal in the water pump, between the seal and the front bearing. If there's coolant coming out of that hole, the seal in the waterpump has failed and the pump needs to be replaced or rebuilt. If not, all systems are go!
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    ade
    ade is offline
    Jul 2003
    154
    Thank you fellas, your replies are very much appreciated. You have saved me a lot of trouble and concern. May your Pugs run for a 100 years!!!
    Ade
