504 diesel question
Results 1 to 9 of 9
    Feb 2001
    Romsey, Victoria, Australia
    4,869
    Default 504 diesel question
    Question for the diesel experts out there.
    What does a 504 diesel engine and 4 sp gearbox weigh?
    I have to send a complete unit with starter motor, inject pump, alternator, power steer pump, clutch and gearbox interstate and the whole unit is to big for me to weigh.
    Usually in this situation I lift it myself and count how many times my back cracks and that tells me the weight but this is just to big and heavy for me to lift so I'm asking for help.
    Anyone with a resonably accurate figure please let me know, doesn't need to be exact, just a calculated guess will do.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Burswood Western Australia
    428
    No idea... but here's my guess.
    Entire car weighs around 1200Kg
    Has about a 60/40 weight distribution?
    So from the centre pillars forward would be about 720kg
    Now take away all of the front half of the body, including glass, seats, carpet etc, now remove all the front end, front wheels, tyres, radiator, battery etc,etc,etc and I would thing you would have around 250 -280 kg left????
    Now...since when did a 504 Diesel have a 'Power Steering pump"???
    5,312
    Quote Originally Posted by David Cavanagh View Post
    Can't help with an accurate figure. Would an hourglass figure help at all?
    Helpful is my middle name.
    Mike.
    Started out with nothing, still got most of it left.
    428
    Definately!
    Feb 2001
    4,869
    Quote Originally Posted by catshamlet View Post
    Mike.
    I knew there were some helpful people out there.
    Rod, this ended its life in a 505SR wagon so it ended up with power steering.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    428
    Ok...so add an extra 5kg, to my caslculations, for the P/S pump!
    Aug 2005
    Merimbula, NSW, Australia
    323
    Crankshaft & Flywheel are around 20kg's each
    Nov 2005
    Sunshine Coast
    350
    David,
    get hold of a spring balance, and make up a lever by drilling a hole in a lump of 4x2, so that the ratios of the lengths from the ends of the timber to the hole are 2:1, 3:1, or whatever - depends what spring balance you have. Suspend the beam from the hole and lift the engine etc on the short end, by pulling down the long end with the spring balance. Multiply the answer by 2, 3, or whatever.
    Various other solutions of a similar nature suggest themselves. I have used bathroom scales and a lever to do the corner weights on race cars. Rough'n'ready, but better than a guess.
    Tim
    Feb 2001
    4,869
    Quote Originally Posted by tcusack View Post
    David,
    Tim
    Thanks Tim I'll work out something.
    I usually just use bathroom scales because usually its just an engine or just a gearbox and easily managed but this whole thing makes it harder, I was thinking of separating the motor and box.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
