405 Diesel Query
    Christchurch/New Zealand
    13
    Default 405 Diesel Query
    Can someone tell me please where the two overfuel lines go from the two end injectors (cylinders 4 &1) it appears number 4 line goes to the fuel return line coming off the pump but where does no 1 cylinder (flywheel end) line connect up to?
    Car is `92 1.8 turbo model with the Lucas/CAV pump.-bought car with engine partially disassembled requiring head gasket. Haynes manual does not give fuel flow diagram and no obvious connection point.
    Richard Jones
    Aug 2005
    Merimbula, NSW, Australia
    323
    It usually has a blanking cap on it.
    Member Hillbilly's Avatar
    42
    Yes. One goes to fuel return line, while the other has a blanking cap. You can get these from any good diesel specialist for a couple dollars.
    May i suggest you replace all fuel overflow lines coming from the injectors as the old ones, once disturbed, have a tendency to leak. Again, easiest source for these is your nearest diesel specialist.
    Good luck with the re-assembly of the head.
    Ryan
    '94 Peugeot 405 SRDT
    12,264
    not only do they leak but if you can get them back on again it would be a miracle as they tend to go rock bloody hard
    new ones or a length of line is cheap so well worth the effort
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    13
    Thanks chaps, I was begiining to wonder about whether it had a blanking plug.
    You are so right regarding the line going hard but already bought the new fuel hose-something I`ve learnt from the past.
    Many thanks to all that answered. Just off to buy a new battery as the tip to use epsom salts to restore a sulfated battery hasn`t worked in my case-there goes another $200-$250.
    Richard Jones
