307 Key Fob - disassembly
Results 1 to 7 of 7
    111
    Default 307 Key Fob - disassembly
    Hi all,
    My key fob for the 307 has decided that the position to lock the key away is now an approximate 30 degree angle from the housing. I had a problem a month or two ago where the key locked itself in the housing and it took a while to get it back out again, only releasing itself after I dropped my keys on to the ground.
    Anyway, how to I disassemble the key fob so I can fix it up again so it all locks back how it should?
    Sam.
    Fellow Frogger! Monsieur 405's Avatar
    Sydney, Australia
    266
    Argh! They're bloody expensive to replace if I remember correctly... probably the kind of thing best left to the peugeot mechanics so if they stuff if up, you'll get a free new one...
    Monsieur 405
    Sydney, Australia
    526
    Have you tried sourcing a replacement key fob on ebay? I just bought one for my 206 as it recently died. Only $6, delivery included.
    Bad_Karma
    "The great philisopher Bashra once said... A flute without holes is not a flute, a donut without a hole is a danish" Ty Webb, Pro Golfer, CaddyShack
    111
    Quote Originally Posted by bad_karma View Post
    Doesn't the 307 one have some RF transmitter for security reasons?
    Quote Originally Posted by Monsieur 405
    Cost us $300 to get an extra one when we bought the car.
    There is nothing wrong with the operation of the fob at all. It's just that the key won't lock away properly anymore.
    Fellow Frogger! PeugeotRob's Avatar
    Southern Highlands NSW
    149
    Quote Originally Posted by sgt_doofey View Post
    Hi all,
    Sam.
    Sam,
    I have had my 307 Key Fob apart once to replace the battery. It is quite easy, just carefully and slowly prise it open at the base, adjacent to where the key ring goes through the hole. In the centre, there should be a groove to fit a screw driver.
    I am a bit pedantic and replace the small battery every two years
    Rob
    2007 Peugeot 307 XSE
    ____________________________________________
    Previous Peugeots: 1995 306 XT, 1997 306 XT
    111
    Thanks Rob. I did have a crack at it, but didn't put much force in to it through fear of breaking something. Is there anything I should look out for when opening it up? Nothing will shoot out and get lost somewhere, e.g. a spring?
    Also, what size screwdriver did you use? A small one or a larger one that fits in the groove?
    149
    Sam,
    I used a large blade screwdriver. Just lie the key fob on a table or bench, with the Peugeot Lion facing up (from memory). Slowly and gently prise the two halves apart. I was apprehensive about opening up my key fob to replace the battery, however nothing shot out when I prised it open.
    When you have sorted out the retracting key mechanism, it is a very simple matter of snapping the two halves back together.
    Rob
