405 SRDT Coolant bleeding procedure
Results 1 to 2 of 2
  • 1 Post By Hillbilly
Thread: 405 SRDT Coolant bleeding procedure
    Member Hillbilly's Avatar
    42
    Default 405 SRDT Coolant bleeding procedure
    Here is some info courtesy of pugrambo that was lost post-crash on the coolant bleeding procedure for the 405 diesel, which can be quite difficult to get all of the air out of. Luckily, I had his post saved to my computer for when I changed the coolant in my car.
    So here it is, ready for anybody else that may need it.
    these can be a bugger to bleed and takes a few goes to get all the air out and what makes it worse is there is only
    one bleed point in the system just near the thermostat on the hose
    i have found the best way to do it is to loosen the bleeder, fill the radiator right up to the top and keep filling
    untill you get a good stream of coolant from the bleeder
    then tighten it up and put the rad cap back on
    start the car and get it up to operating temp, now this will take a while so go and have a beer/coffee/smoke while
    you are waiting then have another as the car will still be coming up to temp
    when it finally gets there just crack the bleeder again and see what you get
    more air will be the answer. once you get coolant again tighten it up and shut the car down
    let it cool and check the level in the radiator, it will be down
    top it up and open the bleeder up again and follow the above procedure again
    once you do this 1/2 a dozen times you should be getting close
    over the next couple of days repeat the above untill all is normal
    the day you crack the bleeder and you get coolant coming out without air is the day you can relax
    this is the only method i have found that works on 405 SRDT's
    406's are much better and have more bleed points and can have the coolant drained and replaced in just over an hour from go to whoa
    james h likes this.
    Ryan
    '94 Peugeot 405 SRDT
    Fellow Frogger! Monsieur 405's Avatar
    Sydney, Australia
    266
    cheers man!
    Monsieur 405
