406 glow plugs dead
    Fellow Frogger! andrepug's Avatar
    Victoria
    455
    Default 406 glow plugs dead
    The glow plugs on my 406 srdt are dead. No light coming on and no heating from the plugs. They are quite new. Is the glow plug circuit on a fuse as I can't find one blown or listed in Haynes.?
    64
    There should be a relay near the battery I'm pretty sure.
    Victoria
    455
    Yeah, it's under the accelerator sensor unit and the air cleaner box has to be removed but what do I do when I get to it?
    64
    If you've got a test light handy easy way is to turn on the ignition with the relay out of the holder and put the test light at each of the connectors on the relay holder and two of them should light up at the start when you put your ignition key on then one should go out the other should stay on. If that all checks out okay, probably have a blown relay.
