504 brakes
Results 1 to 3 of 3
Thread: 504 brakes
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    625
    Default 504 brakes
    What happens if the brake pedal is pumped when the car is idling ?
    Should RPM go up or down ?
    In a friend of mine's car, RPM used to go up when pumping the brake pedal and then he installed electronic ignition and now the car almost stalls when doing it.
    Any advice ?
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Dec 2002
    Menzies Creek
    2,541
    Pumping the pedal allows a small amount more air to enter the intake through the brake booster. If the engine is already running rich at idle, it will make it run faster. If the engine is running lean, it will slow it down. If the engine is running just right, it shouldn't make much difference, perhaps slow it down a little as it leans out a touch.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Cairo, Egypt
    625
    Chadi
    All since new
