604 Front doors same as 504 ?
    Hobart
    1,496
    I have been told that the front doors of a 604 are the same as the front doors on a 504 ? is this true ? if so that would be great !
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    Ben,
    Yeah, the doors are the same, BUT the window frame part of the door is different. The window frame seems to be welded onto the door, but it should be possible to cut, swap and re-weld. I don't know how difficult this is.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    12,269
    from what i worked out the series one 604's had the same door but the series two had a different window frame in them
    interior door trims aren't the same though and won't interchange between 504 and 604 doors
    there were a few minot changes between series 1 and 2 604's
    if you want to know more just ask
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,223
    Sorry, pugrambo... it's not possible. The windscreen rake of the 604 is greater than the 504, hence the window frame is different to the 504.
    The doorskins are the same as the 504s from the point when the liftup doorhandles came in... was that 1975/76?
    Why do you ask, anyway? If you need some doors, just ask...
    [ 25 December 2001: Message edited by: Ray Bell ]</p>
    Hobart
    1,496
    Cheers All,
    Today I was given a 604 which had been laid to rest after a *I have been told common* engine bay fire, the engine bay is stuffed, but the panels are all good !!
    Ben
    1973 Peugeot 504 GL
