406 Coupe Battery
    1000+ Posts kermit's Avatar
    Jun 2002
    Inner city, Brisbane
    2,335
    Default 406 Coupe Battery
    The original has just died after 5yrs and 80ks Replacement cost me $150 from Marshall @ Greenslopes. The replacement (made by Exide in Asia) has the same dimensions as the OEM, a 2yr warranty and is rated at 600CCA. The OEM was 450CCA.
    Cheers Simon
    >8-]
    Rendezvous Adelaide 2005
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    12,266
    Quote Originally Posted by kermit
    DIN66 ??
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Jun 2002
    2,335
    DIN66 ??
    PDIN66 http://www.marshallbatteries.com.au/range.php
    Cheers Simon
    >8-]
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    12,266
    thought so
    marshall is exide as are many other brands
    the 450CCA is what a DIN55 puts out and the DIN66 is the 600CCA and a bigger casing as well over the DIN55
    most of the smaller pugs run the DIN55 while some little ones run the 37A
    next one up is the DIN88 but it is a bigger casing again and most often used in forklifts would you believe
    1 x 2018 3008
    Oct 2000
    Auckland, New Zealand
    533
    I thought DIN66 was 550 CCA? I just put a Delphi DIN66 in my 405 yesterday and it's 550 CCA, as is the Lucas DIN66 in my uncle's 156.
    I guess there's a little variation in the standard?
    12,266
    Quote Originally Posted by Louis
    each manufacturer's specs are slighty different
    i can only quote exide specs
    exide includes marshall, masse, champion, john deer, new holland, volvo, mitsubishi, holden, case, power breed
    so you can see they cover a fair wack of the market
    1 x 2018 3008
