Battery for 'S1' 405.
Results 1 to 2 of 2
    Oct 2000
    Auckland, New Zealand
    533
    Default Battery for 'S1' 405.
    Hi, I'm pretty sure the battery in my 1990 405 has pretty much had it. It was flat when I got in it last Saturday morning, and again this morning. My mechanic has previously noted that it's technically too small for the 405 and hey I only bought it second hand for $40 a year or so ago.
    Do I need a specific 'European' battery for it? I've been told you can actually get away with a regular battery but I thought I'd check.
    I've seen the term 'DIN55' and 'DIN66' floating about, how do these differ?
    Nov 2002
    Yarrabilba, Queensland
    2,758
    I am not certain but I think 'euro' batteries have the terminals recessed into the top of the battery? Like I said I am not 100% sure but that's what I have been lead to believe and both the Cit Xsara we have and my Scenic have this style of battery and I know that a friend with a GTA was after this style too.
    I'd check if your Pug should have that too because if a normal battery of the same size is used and the terminals add to the ehight you could end up with a problem like I have seen on some cars where the terminals will hit under the bonnet...kaboom
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
