405 mi16 fuel pump
Results 1 to 2 of 2
    Tadpole qubix's Avatar
    Feb 2006
    Poland
    4
    Default 405 mi16 fuel pump
    Hi @ll,
    I'd like to know if anyone can help me!!!
    Fuel relay, where can I find it?
    my fuel pump doesn't work couse +12V is out.
    when I attach wire to + of lighter- the fuel pump start working
    I saw at Haynes manual that the relays are in black box nearby ABS pump
    but.... In Haynes there are 2 relays and 2 fuses, in my car Mi16x4 dated 91' there are three of them... what can I do to push my pump to life without connecting it to battery?
    Hi @ll, regards
    Tomek
    Aug 2002
    NSW
    79
    On the series 1 Mi 16 the fuel pump relay is in the box behind the ABS set up. Check these relays and the fuses attached. My fuel pump played up because the wiring into the relay was burnt . Replacing just the last few cm of wire, new fuse holder and relay and problem disappeared. Greg
