Nah, I won't need a spare tyre (GTi180)
Results 1 to 23 of 23
    Member ewen75's Avatar
    Nov 2005
    64
    Default Nah, I won't need a spare tyre (GTi180)
    Pigs arse !!
    So I got home from a big night at the casino last night, went to drive my car (about 6pm) and the rear tyre is flat (there's a nail stuck in there).
    Having a spare would be handy about now too, saturday night and all.
    '05 Aegean Blue 206 GTi 180
    Fellow Frogger! Dr_Pug's Avatar
    548
    Quote Originally Posted by ewen75
    Pigs arse !!
    Did the pressure kit not save you? Did you have to pug assist to have it towed?
    You might want to check this thread out about an alternative spare.
    Cheap alternative for a 180 spare rim
    04' GTi 180
    Jul 2005
    328
    Pity peugeot decided to go without the spare. They had such a good design with the 205 and 505 (and I guess most other older pugs, but I haven't changed a wheel on anything else).
    None of this unloading the boot business (think raining night on a road trip - wet luggage!). 30 seconds and you're ready to jack-up the car and pull the ole switcheroo!
    '96 Peugeot 405 SRDT Station Wagon
    '71 Peugeot 504 GL - gone
    '91 Peugeot 205si - gone
    Nov 2005
    64
    Luckily it was in my driveway, so didn't need a tow.
    I've got a mate who owns a goodyear, he'll see me right monday morning.
    I'm kinda spewin though as we're going up to Mt Barker tomorrow and I would've loved to have taken the Pug.
    I might have to see about a spare, thanks for the link.
    Member dpcgti180's Avatar
    Nov 2005
    hobart
    97
    Did you use the can?
    05 206 GTI 180
    04 407 ST
    94 306 XT
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Quote Originally Posted by scatterbrain
    Only in the GTI180 and 206CC (other 206's have a spare).
    ewen75, a genuine 180 rim is expensive, a space saver will get you out of "most" troubles in the suburbs (speed limited to 80kph).
    - xTc -
    Now this is a .sig
    Nov 2005
    64
    Quote Originally Posted by dpcgti180
    Yes i used the can. However I didn't (as instructed in the manual) either deflate the tyre first, or remove the nail and it appears to have worked fine. A day and a half and it's still inflated.
    I could still hear the air leak out of the tyre right after I'd used the can for a few minutes, then I walked away, came back some time later and the leaking noise had stopped and the tyre appeared still quite inflated. I added a bit more air/foam from the can and it's been fine now for a few days. Even though I've only driven it to the shops and back twice (about a 1-2k round trip).
    I'll look at getting a 206 standard steelie or space saver as an option in case this happens again.
    Nov 2005
    hobart
    97
    So let me get this straight.
    You used the can,
    You ignored some key elements in the instructions for using the can
    You found that even though the you ignored the instructions the can still worked
    SO,
    you wish to complain that the COMPACT and LIGHT can worked satisfactorily and you have now decided that you are going to buy a LARGE HEAVY wheel to replace it !
    WOW , yu is real smart man
    05 206 GTI 180
    04 407 ST
    94 306 XT
    XTC
    XTC is offline
    Mar 2003
    8,566
    A 14" standard 206 Steelie will not fit over the front brake discs, a 15" Steelie will just (with 3-4mm to spare), you should look for a 16" if possible. Only 16" that you will find in steel that suits is a C4 16" steel rim, but new they cost $180 trade price .. Ouch !!
    - xTc -
    Now this is a .sig
    Nov 2005
    64
    You used the can,
    SO,
    Well actually not quite. The reason I didn't follow the instructions to the letter was that when Peugeot rotated my rear tyres (due to the fact that when fitted at factory or whatever reason they were rotating the wrong way) they didn't put back the wheel lock remover and so I couldn't remove the rear wheel to remove the nail.
    Also didn't actually complain at all the can worked, I bought the car knowing it didn't have a spare, but if I had a spare sitting in the garage i would've been able to use my car on the weekend more than reluctantly driving to the local shop and relying on getting a lift somewhere, hence wanting a spare for any future problems with tyres.
    But I appreciate the IQ test dpcgti180.
    Sydney, Australia
    526
    Hey fellas
    I carry around a tyre puncture repair kit in the back of my car and keep the tyre-in-a-can as a last option. The kit contains a tyre repair kit that you can buy from most auto stores, the same stuff a mechanic would use to plug your tyres if you came up to em with a flat. And I also carry one of those compact air compressors you can pick up at supercheap for about $15.
    Might be a good alternative to carrying a whole spare wheel.
    Bad_Karma
    "The great philisopher Bashra once said... A flute without holes is not a flute, a donut without a hole is a danish" Ty Webb, Pro Golfer, CaddyShack
    1000+ Posts kermit's Avatar
    Jun 2002
    Inner city, Brisbane
    2,335
    Quote Originally Posted by bad_karma
    I would think the can of goop would be easier to administer on the side of the road than trying to repair a puncture. Tyre shops take the tyre of the rim when repairing punctures, you won't be doing that on the side of the road.
    Cheers Simon
    >8-]
    Rendezvous Adelaide 2005
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    Sydney, Australia
    526
    Quote Originally Posted by kermit
    This kit doesnt require taking the tyre off the rim. The link below showsone in use. I got one of these kits in the back of my car just in case. The good thing about this setup is that you dont have to replace the tyre as you would with the tyre in a can.
    http://cgi.ebay.com.au/PUNCTURE-TYRE...QQcmdZViewItem
    Bad_Karma
    Nov 2005
    hobart
    97
    Oh, I see now!
    So, since you were unable to remove the wheel from the car you wanted spare wheel!
    How exactly were you going to attatch it without removing the other wheel?
    Man, if i were you i'd be mighty pissed about that can!
    05 206 GTI 180
    04 407 ST
    94 306 XT
    Nov 2005
    64
    Getting a little excited there Princess?
    Thanks to everyone else who offered constructive and informative input into this thread, very much appreciated.
    Sep 2003
    North Parramatta
    3,997
    Gee, these 180 wheels can really stir the blood
    Anyway, so now that we've established you used the inflatey foam, what are your thoughts? Is it a good method of resuming your journey (ignoring the fact that you were parked at home at the time...), and have you since had the puncture repaired properly?
    I've never used one, and I'm dying to know why some people (maybe even the manual - I can't remember) say that the tyre must be replaced afterwards. Also (the all important question) how much is a replacement can?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Nov 2005
    64
    It did what it needed to do, that is sealed the hole and got me going as far as I needed to get it fixed.
    The chap who fixed my tyre (friend of mine, owns his own Goodyear Centre) said something about the sidewalls of the tyre can be damaged after driving when the foam is used? After inspecting the tyre he repaired it, advised it should be fine and off I went.
    It was a drill bit that punctured the tyre by the way.
    Sep 2003
    North Parramatta
    3,997
    Cheers for that. I've always been a little suspicious of the "written off tyre" theory myself.
    I still wonder what sidewall damage it could do.
    Simon
    XTC
    XTC is offline
    Mar 2003
    8,566
    Quote Originally Posted by SLC206
    They just play on the safe side, don't want to get sued.
    - xTc -
    Now this is a .sig
    Nov 2005
    hobart
    97
    You dont get it,
    The amount of complaints and whinging about the cans that do their job fine is incredible.
    Keeping a spare in your shed is fine but really who is gonna drive around on a steely. Might as well just use the can till you get it repaired.
    If there was a spare in the car it would no doubt be a cheesecutter thus making it less effective,more difficult and more time consuming than a can.
    If i had a choice when i bought it i would have stayed with the can.
    But for **** sake, stop complaining about a spare in a can item that outperformed any other realistic option.
    Take a look in most peoples boots and you will probably find an underinflated bald tyre anyway. I'd swap them for a can too
    05 206 GTI 180
    04 407 ST
    94 306 XT
    Sep 2003
    North Parramatta
    3,997
    I'm resigned to the can (if ever it's needed) but I do possess a full-size alloy rim (complete with old P7000) for sidewall failures if required. I never carry it with me, save for the trip to Adelaide I made last year for Rendezvous Adelaide
    The can is definitely the preferred option for me, depending on the failure of course
    If it had happened in my driveway (and I didn't really need the car) I would have just removed the wheel and bludged a lift to a tyre place.
    Simon
    Nov 2005
    64
    You dont get it,
    Who's complaining about the can? I think someone needs a Vallium.
    For a near brand new $300+ tyre I wouldn't want to risk driving around on it over a whole weekend in case of permanent damage, and in my given situation a spare tyre kept in the garage would've been IMHO a better option for me for my day to day car. So before reading into peoples post and then firing up I suggest you actually understand what they're getting at, and get a fkn sense of humour.
    This, apart from yourself, was an interesting conversation for most as to the actual experience of someone who had to use the can. And again I appreciated peoples constructive input in what I thought was a forum for helping people out with an interest in french cars.
    548
    Quote Originally Posted by XTC
    - xTc -
    That is not true it is more like 3-4 cm of space between the caliper and the rim when fitting a 15 inch steelie on the front and there is no rubbing against the rim or inner skirts.
    If you think that 3-4 cm isnt enough, you could always put the 17inch on the front and the 15inch on the back
    04' GTi 180
