405 sri engine dramas
Results 1 to 3 of 3
    Feb 2006
    australia
    2
    Icon5 405 sri engine dramas
    as an occasional problem, when in neutral and idling, the rev's will drop to about 1000 rpm, the car will idle, normally. Then, mysteriously, when 1st is engaged and the accelerator is tapped then released, the revs will drop and the car will stall. It may be a computer sensor? or another mechanical glitch? any suggestions or ideas on this issue??
    Tadpole IBLOWN's Avatar
    Feb 2006
    Penrith, Sydney
    25
    sounds like an IAC problem
    Peugeot 405 sri 94' everyday. Commodore once a month.
    http://www.cardomain.com/ride/2213367
    Jul 2004
    896
    check wires going to map sensor which is behind the radiator at the top. I had similar probs and found a wire had broken due to engine movement and not enough slack in the wires.
    Decca
    Present --2016 2008 Outdoor / 2014 RAV4 Diesel (My utilitarian beast)
