306 gti6 lowered front coils
Results 1 to 18 of 18
    Sep 2005
    adelaide
    67
    Default 306 gti6 lowered front coils
    have not had much luck finding these, the best i can do is the new koni coils for $350 on my doorstep
    according to my mechanic these are not great and he has suggested eibach if i can find them
    but have not been able to find anything - any hints?
    1000+ Posts U Turn's Avatar
    1,761
    WRCPUG has fitted them to his gti6 before. See Eibach Springs for 306 Opinions Needed
    Take the long way home....
    - 306 gti6
    Member pokinacha's Avatar
    Apr 2005
    87
    Go to http://www.eibach.com.au/
    buy direct from Eibach. they work well with OEM shocks...
    I have them on my SV.
    Question: how do i reset the rear springs? the back is a little high...
    Tim
    Sep 2005
    adelaide
    67
    Quote Originally Posted by pokinacha
    Tim
    you adjust the splines, no purchase necessary
    Apr 2005
    87
    Quote Originally Posted by alexb618
    How do i do that?
    Fellow Frogger! mmm...CORNERS's Avatar
    Epping, Sydney
    574
    Just a note: The eibachs work well, however dont expect the quoted 35mm drop. You'll be luck to get 10-15mm. They are really just a touch firmer than stockies, helping reduce roll a bit. Although, you will notice small bumps heaps more.
    Sep 2005
    adelaide
    67
    so are you suggesting i drop the rear and dont touch the front?
    the car is pretty high at the back (standard height), i suspect it will be 4wd-like with the 17s on it unless i drop it a bit
    1,761
    Alex, are you thinking of putting 17's on the gti6 with stiffer suspension? Make sure you get the springs/shock combination spot on. I drove a S16 with 17" wheels and some progressive rate king springs with the stock shocks, and it rode poorly and handled even worse. It didn't bodyroll but that maybe because it started understeering before the fronts could key into the road surface hard enough to even cause bodyroll.
    - 306 gti6
    Epping, Sydney
    574
    If you are putting 17's i strongly suggest some specially made progressive springs. Like i said the eibachs wont lower that much. You will have to reset the rear about -30mm, but be prepared for scrubbing, crappy ride and iffy handling on anything but billiard tables. When resetting the rear, make sure the splines are marked with a standard height reference, so its easy to revert should you ever want to.
    A car like a 306 suits nothing larger than 16's IMO
    Fellow Frogger! WRCPUG's Avatar
    May 2002
    Glen Iris, Melbourne
    1,035
    dont get kings whatever you do
    If you want a minimum drop in height and an improvement in handling get the Eibach Pro Kit.
    If you want a harder more track orientated Eibach get the Eibach Sportline springs
    If you want a harder ride and bigger drop with improved handling get the Apex springs. I had these on with my 17's and they werent too bad. At Philip Island i had standard shocks with Apex springs reset to sit lower using my 15" wheels and i couldnt really fault the handling.
    PEUGEOT 306 GTi6 (1997-1999 HYBRID)
    105.4kw (141HP) ATW
    2:09 Phillip Island (Toyo Street Tyres)
    2001 YAMAHA YZF-R6
    119HP
    1993 MITSUBISHI 3000GT Twin Turbo
    300BHP
    STOCK-14.006 @97.4mph HEATHCOTE
    STOCK-1:15 CALDER Long Circuit (Stock Street Tyres + Stock Pads :banghead )
    (For Sale)
    Sep 2005
    adelaide
    67
    thanks for your input everyone, i will have a look into these apex springs
    and having built a number of cars from the ground up over 10 years i am well aware of what 17s will do to the handling
    but i am going to do it anyway
    so lets not argue about it
    May 2002
    1,035
    hahah nice i dunno how many times ive had to explain myself also
    If you get some nice light 17" wheels that weight less than the cyclones then im sure the car will handle just as good. May i suggest OZ wheels
    105.4kw (141HP) ATW
    2001 YAMAHA YZF-R6
    119HP
    300BHP
    (For Sale)
    1,761
    wrc, those wheels look sensational! Are they really lighter than the cyclones? What're they worth?
    - 306 gti6
    May 2002
    1,035
    The ones on the red rallye are OZ Superleggaras...OZ make lightweight wheels as used in WRC ect.
    i got a quote years ago for the OZ Supertursimo in 17" and they wanted $800 a wheel So yeah expensive.
    http://www.ozwheels.com.au/store/list.inetstore?id=3
    105.4kw (141HP) ATW
    2001 YAMAHA YZF-R6
    119HP
    300BHP
    (For Sale)
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,012
    mmm
    405 Mi16 - Sold - Now back
    205 Mi16
    505 GTi
    1,761
    mmm
    It looks just a bit too big on the 205. I reckon one size down would look horn. I was just checking the ozwheels website..they've got one wheel there that's 1600 bux a wheel!!! faaark
    - 306 gti6
    al
    al is offline
    Dec 2004
    2,012
    Quote Originally Posted by U Turn
    I didn't even think they would look good on a 205... But i'm realising that those wheels would look good on anything.
    I'm quite liking that splitter too.
    205 Mi16
    505 GTi
    Epping, Sydney
    574
    man those OZ rims look sweet, good enough to to justify 17's! but you'd really have to have the sitting really low so it dosnt look like it tippy-toeing
