Electric Windows Stuck
Results 1 to 7 of 7
    I might be slow... DRTDVL's Avatar
    Auckland
    1,288
    Default Electric Windows Stuck
    Hello one and all...
    I went for a good drive on some twisty roads and now i think i've seized the passenger window in the frame....
    I've taken the door apart and i can hear the motor working but it just ain't movin the glass....
    i've checked all fuses, and i can feel the motor when i click the buttons...
    any idea's?
    Member senthil16V's Avatar
    malaysia
    102
    Quote Originally Posted by DRTDVL
    any idea's?
    Probably the plastic window lifter is broken or the plastic piece that holds it in place have come loose...had that before on my car as well...
    With Rgds,
    Senthil16V
    Auckland
    1,288
    the moter arms don't move either... so it's not like the motor is moving and the glass isn't
    Member Luke G's Avatar
    Blue Mountains/NSW
    86
    I recently replaced the electric motor on my 405 s2 which I am guessing is the same as the 406 or atleast similar (I may be wrong). The way the system works is there is an electric motor connected to a set of plastic cogs which when activated pulls on a set of cables that feed around a set of pulleys and pull the window either up or down. The problem was in my case was that the plastic gears had cracked.
    Auckland
    1,288
    nope it was just stuck...
    was driving home last night and decided well let ust try it one last time... and the window went down and up and down and up....
    all fixed
    malaysia
    102
    yeap had that problem too...sent it to my mech...he changed the pinion gear, rewound the cable, regreased them...charged me AUD 60 which is ok considering brand new power window unit is AUD 360...
    its been good so far...
    With Rgds,
    Senthil16V
    Member Griff180's Avatar
    Sep 2004
    Perth
    67
    I've had the 180 do it a couple of times. Bit worried about it.
    2004 Black 206 GTi 180
