505 replacement wheel studs?
Results 1 to 2 of 2
    Gus
    Gus is offline
    Fellow Frogger! Gus's Avatar
    Jun 2002
    Canberra, Australia
    600
    Default 505 replacement wheel studs?
    Is it possible to replace the wheel studs in a 505? Can you get them from anywhere? Do they come with new brake rotors (and, if so, does anyone still make brake rotors for a 505?) Or am I better off just waiting till I find a 505 with good condition hubs (if there are any left), and cannibalising those.
    There are some web sites with US companies listing replacement rotors, although they look pretty suspect.
    Thanks for any/all info. .
    Fellow Frogger! Meggsy's Avatar
    351
    try -http://www.eai.net.au/
    there are also other locally available non genuine rotors but fro memory the studs are through the rotors from the hub and are reasonably easy to replace its been a loing time since I did it and then it was in a 504.
    I am sure many others have more recent experience
    Cheers and good luck
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
