205 Cold Start Problems
    Feb 2006
    Strood, Rochester, England
    1
    Default 205 Cold Start Problems
    Hi,
    Does anyone have any ideas on how i can solve my cold start problems. I have got a peugeot 205 gti 1.9 and on cold start it turns over but then cuts out straight away unless I keep the revs up to about 1500 rpm for approximately 30 seconds, then it sits there untill warmed up when it drops down and idles nicely at 900 rpm. I have tried a different Supplimentary Air Device which I know to be working correctly and I have also tried another Air Flow Meter (which I also know is good), I have played about with the ignition timing to see if that makes any difference but no luck as yet.
    If anyone else has any thoughts it would be much appreciated.
    1075.6 SamR's Avatar
    May 2004
    1,392
    Hmm, sounds very much like the problem I've been having with my car except that I have to keep the revs up for longer. I've been meaning to get around to replacing/cleaning the SAD but haven't yet
    Sorry I can't offer any solutions but I'd be interested to hear if you do manage to solve the problem
    1989 205 Gti - Sold
    "This year, I invested in pumpkins. They've been going up the whole month of October and I got a feeling they're going to peak right around January. Then, bang! That's when I'll cash in." - Homer Simpson
    Ipswich, Queensland.
    1,913
    The engine temp sensor for the injection system may be defective telling the computer the engine is warm, and so not giving it a rich enough mixture. When cold it should have approx 2000 ohms resistance, and when hot maybe 200. These are approximate figures, but you get the idea.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    02 and 03 Renault Clios 1.4L
    Aug 2005
    Liverpool NSW
    317
    Quote Originally Posted by alan moore
    The engine temp sensor for the injection system may be defective ...
    im thinking the same if u've tested the other bits which may be causing the prob.
    Puggy.
    JAMAICA
    48
    is this SAd the same thing as the cold start capsule? don't know if your car is carb. I had that problem with my 405 carb and it was the capsule that was bad.
