504 engine identification & production year?
    Fellow Frogger! Phil Whitton's Avatar
    Bargo Sthn Highlands NSW
    273
    Default 504 engine identification & production year?
    Despite vast searches somewhere there was a listing of the 504 engine numbers and the year os production.
    I've a twin carby 504 with an engine number of 2976766X that I'd like to know the year.
    Any leads?
    merci
    Fellow Frogger! Meggsy's Avatar
    351
    I have a recollection that these were a south african import but I am not sure
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
    Jan 2006
    6
    These were sold here in about 1978 or 79 to meet the polution controls at the time. If you look on the side of the block, not certain if you can see withour the engine out, there will be a date like 24A78. The A or whatever is the month the block was cast - so you will get somewhere near it. There are also dates on the gearbox and diff, back of steering wheel. Hope this is of use to you. I will check with someone else tomorrow.
    Graham
    273
    Default numbers
    Yes thanks: the engine is high and dry on the hoist so Ill check the casting. There is no body that I could check any of the usual number areas: steering wheel, gearbox, axel housing.. and my history books are on the ute which is up on the hoist.
    Merci
    Phil;
    273
    yep thanks ; its a 76. Carby kits are starting to dry up too. Fuelmiser have removed them from their listing.
    Look for old stock..
    bon chance
