Wiper Blades: The rubbery bits
Results 1 to 8 of 8
    Fellow Frogger! xonicjan's Avatar
    Nov 2003
    120
    Default Wiper Blades: The rubbery bits
    I wanna change the rubbery bits on my wiper blades cause I hate the Pug ones. They are new but still streaky. Yes, Ive had them adjusted.
    Anyway I bought some once that totally did not fit. What a waste of money.
    What I want to know is what kind of wipers you use especially on a 206. Are they genuine pug blades or another brand?. I did a search and one guy recommended trico.
    if i get teflon coated ones will they give me cancer?
    Fellow Frogger! J206GTI's Avatar
    Jun 2003
    BIG Gravel Island
    357
    Quote Originally Posted by xonicjan
    The Trico Teflon ones are good, only for a short term, they are quiet but once the coating is wearing out it'll be noisy.
    Since they moved the factory from australia to china I started banning it so I gone back to get some Bosch MicroEdge wipers, they are great, noisy every now and then but much better quality and lasting longer I think.
    If you have a CAMS license you can get the bosch refill blades for $3 only at Burson Autoparts !!
    Jason
    206 GTI MY01.5 Oversteer Edition
    Myth Buster Logic : red cars go faster !!
    Red Car Bling factor :
    1000+ Posts kermit's Avatar
    Jun 2002
    Inner city, Brisbane
    2,335
    Only if you cook them in a teflon fry pan, ha ha!
    Cheers Simon
    >8-]
    Rendezvous Adelaide 2005
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    Nov 2003
    120
    Quote Originally Posted by kermit
    Fellow Frogger! Meggsy's Avatar
    351
    Just remember that many of the pug baldes are 7mm not the standard 6 or 8 therefore go for the 8mm ones and spread the blade tracks --- yr stuffed if its plastic though.
    If you have the wrong sized blades then they become noisy
    cheers
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
    Banned orestes's Avatar
    Sunshine Coast
    4,520
    I just picked up some generic ones for my 205 from autobarn. Alls you have to do is cut them to suit your wiper blade length.
    Other then that mine work perfectly, and I haven't had a problem. I can't see the reason in buying anything more expensive but i'm sure someone will give me a good reason.
    Oh yeah, by the way, if you bought some one size fits all generic wiper blades then you have to cut them to suit the length of your actual windscreen wiper
    Sep 2003
    Boolarra Vic
    95
    Default Try EAI
    European Auto Imports in Boxhill have the correct inserts for the OEM Valeo wipers.... They certianly fit better than generic ones do.
    Alternatively you can buy any complete wipers for $10-20 from Autobarn/BigW/Supercheap and then you wiill be able to use the generic refills as well next time... Just get the correct length and they come with a large selection of mounting clips to connect to the wiper arm. You can even get the Aero blade ones like lots of Pugs have on the drivers side if you want
    Trev
    Trevor Hoare
    Boolarra Vic
    '95 405Mi16 - what a great car! ; 89 405 ( for my daughter )
    previously 205Si, 504Ti, HR wagon with R16 seats, R16, R10, VW kombi, VW passat, HQ panel van, FB panelvan, Rover'49 P3 4-light
    Fellow Frogger! Industrie's Avatar
    Brisbane Australia
    635
    Quote Originally Posted by Meggsy
    cheers
    For my 206 I bought 6mm bades & still had to bend the clips out a bit to get them to fit. Took about 20 minutes to get them in, the fitting was way too tight.
