Wheels
Thread: Wheels
    Member Felix205GTi's Avatar
    Nov 2005
    46
    Default Wheels
    Anyone know what other cars share a 4X108 stud pattern, i heard from someone on here that Mk1 golfs have the same pattern, then yesterday i saw a Mk1 GTi that had been in an accident i stopped to have a gander and it had E30 or maybe E21 wheels on it, look like a small alpina wheel, are my eyes deceiving me or am i right???
    Aug 2005
    Liverpool NSW
    317
    as far as i know ford focus + fiesta. keep in mind the offset is different tho so i believe to fit these wheels you need spacers. i was told spacers arent recommended but a friend also suggested perhaps to weld the spacers to the wheels if possible. also at the mechanic the other day was a Mk1 or 2 ford escort(soz but v nice despite the ugly lime green!) so i measured the stud pattern and it was also 4 x 108. i believe early capri's the same.
    Puggy.
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    Could also be worth noting whether the wheel stud on the possible wheels are a tapered stud or a flat base.......... The Pug style is a flat base. Stud diameter is also critical.
    That said, it is possible even if a wheel is a tapered seat and a different diameter they can be filled and redrilled on a mill with an indexing head.
    TIG welded spacers can be done, but should be set up in a lathe to ensure precision and a perfect weld penetration.
    There are also two different length wheel studs used by Pugs I have seen
    Usual legal disclaimers apply.
    cheers
    richo
    Aug 2005
    Liverpool NSW
    317
    Icon14
    Quote Originally Posted by jackafrica
    cheers
    richo
    thanks, i was unaware of this great info.
    Puggy.
    Brisbane, QLD, Australia
    396
    Only ever heard of Mk1 Eskie wheels being the same as the 205 GTi, if you have a series 1 205, just get a set of 15" series 2 wheels, that way you can upgrade the calipers to a set of series 2 without any additional mods.
    Chip
