205si not starting
Results 1 to 9 of 9
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,012
    Default 205si not starting
    My sisters car is occasionally difficult to start, but today it won't go at all. I've checked obvious things, but i'm wondering what else to look for.
    It is turning over fine, but not firing. Plugs, leads, starter etc are fine, although i don't know how to check if it is getting any fuel.
    Any suggestions?
    405 Mi16 - Sold - Now back
    205 Mi16
    505 GTi
    Banned orestes's Avatar
    Sunshine Coast
    4,520
    have you checked the coil?
    I might be slow... DRTDVL's Avatar
    Auckland
    1,288
    have you checked the charge on the battery... or checked to see if there is water in the battery...
    al
    al is offline
    Dec 2004
    2,012
    I checked all the wiring... Anyway, i just towed it into the street and it roll started fine.
    What could be causing this? Sometimes when it is hard to start it spits out a bit of smoke - valve stems? Although, it has only done 125k kms... Perhaps i should do a compression check and see what it reveals...
    205 Mi16
    505 GTi
    Auckland
    1,288
    i had the same problem in the s16 - the battery was dry
    brisbane
    2,908
    Two things come to mind....bad earth especially the one under the battery
    or the ignition module....the age of the car tells me it is due to go soon.
    cheers jr
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    al
    al is offline
    Dec 2004
    2,012
    Quote Originally Posted by jr20516v
    cheers jr
    I didn't look at the earth there, although i have heard that is an issue in the gti... As for the ignition module, is there any way of isolating that?
    Incidentally, i discovered another thing i like about this car - the room under the bonnet!! The inlet is practically not there, and you can sse the starter (and do whatever you want to it) without removing anything... It makes the gti look a little...cramped.
    205 Mi16
    505 GTi
    Aug 2005
    Liverpool NSW
    317
    Quote Originally Posted by al
    ... Sometimes when it is hard to start it spits out a bit of smoke - ...
    can you see where the smoke is coming from? i know its a pain-in-the... but have you double-checked the electrical bits with a multi-meter? my pug was running horrible bout 5 weeks back, changed the plugs, leads, cap, rotor, fuel filter, re-set the timing(also cause rego is soon) & its running considerably better. a compression test can be done if/when you change the plugs.
    Puggy.
    al
    al is offline
    Dec 2004
    2,012
    Quote Originally Posted by 205puggypower
    Puggy.
    It comes from the exhaust, which indicates the valve stems doesn't it? I was suprised by this though as the car is a 93 model, has only done 125k kms and has lived a very gentle life...
    I have been told that smoke can indicate rings too, which would show up in a compression test... obviously i hope this isn't the case, (and i think it is unlikely) but it has been mentioned.
    And i know what you mean about the electrical things... the gti is waiting on a new dizzy cap/rotor/leads/plugs etc...
    205 Mi16
    505 GTi
