Pinging 404
Thread: Pinging 404
    Oct 2005
    Rome
    2,660
    Default Pinging 404
    My '68 404 is running the original engine and very likely has never had the head removed. She doesn't blow any smoke and is very reliable.
    My problem is pinging. I have had her tuned (Colliers at Granville) and she continues to ping. Yes, I have tried the various 98 PULPs and found that Optimax gives the best results (or should I say, the least pinging) but she she still pings when you need every firing stroke you can get (ie climbing a hill).
    I don't really want my mechanic to alter the timing too much because she is much perkier since the tune than before.
    Any ideas?
    12,269
    give it a redex treatment to de carbon the engine
    then read a few threads on here about water injection
    while you are at it keep the flahlube up to it
    if you need instructions on how to redex it let me know and BTW it's fun
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Perth Western Australia
    2,694
    Default Pinging 404
    '68 404,
    It would appear that you or your car is, like a lot of older cars, suffering because of the current fuels. The problem could be exacerbated by the slightly higher compression in the earlier 404's than the lower ratio in the later models ?
    In my opinion you may have to put up with slightly less "perk" to get less "ping". This means you will have to knock back the timing from standard.
    Maybe a slightly larger carb main jet would help, the theory of a richer mixture contributing to combustion cooling ?
    Opening up the valve clearances [cold] by .002" would allow the valves to "rest", allowing them to dissipate heat. My own theory this. Any comment?
    Some type of upper cylinder lube is a must with the "oldies". My preference is for the "Flashlube" product. Ideally with its metered dispenser.
    All the above done one at a time may ease the problem.
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Just out of curiosity, what is your measured dwell angle and Deg advance, (again measured not book spec).
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    Member LynCliff's Avatar
    Cohuna Victoria
    94
    If you are still using the original dizzy the chances are it is giving to much advance at low revs due to wear in the mechanical advance.
    Your vacuum advance could also be faulty.
    I no longer use standard dizzies but get them modified by a tuning friend who changes the whole advance curve to suit the engine.
    EAI in Melbourne used to have New dizzies for a reasonable price.
    Regars, LynCliff.
    Dec 2004
    Gundaroo (near Canberra)
    214
    if you don't want to detune it, when it pings, back down a gear and keep the revs high (If able)
    Lets just say we have a few pugs about!
