MI16 running problem
    Aug 2005
    Scotland
    9
    Default MI16 running problem
    I dont know if anyone can help, but I've got a 92 405 MI16 that runs fine at low revs but when they rise to about half way the engine starts to missfire. I've checked the timming belt and fitted new spark plugs but this still makes no difference. Sorry for no specific revs but the rev counter dosent work at the moment (next project once it runs better)
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Quote Originally Posted by Sheps
    Are your spark plug leads and distributor cap/rotor arm in good order?
    Also, if possible swap your coil for another and test to see if you still have the same problem.
    6,498
    Usually problems with the leads would show up at all revs, but I'd still check this first. Best way is to run it in the dark with the bonnet open, and rev it (manually on the throttle body) until the problem happens. Look for blue sparks all around the plug leads. Obviously you'd need to take the cover off the leads, but make sure they stay in their retaining slots. Unfortunately, this won't tell you if any shorting happens down the plug tube, as you can't see it...
    Sounds like something else, though. Distributor cap?
    Stuey
    2003 PEUGEOT 206 GTi
    Aug 2005
    Scotland
    9
    Cheers for the ideas guys. Will try that and let you know how I get on.
    Aug 2005
    Scotland
    9
    Tried a new distributer cap but no joy the problem still exists . Got leads on order to try that as well. Removed the spark plugs and the look like the engines running rich. Could this cause the problem?
    Sandringham
    41
    Hi,
    Sorry i dont know how to fix you problem, but along the same lines my mi16 is having issues as well.
    My car misfires occasionaly at low revs whilst accelerating from a standstill. Happens around 2000-3000 revs and pretty much only when im moving off from a stop. If i feed it a few more revs it runs fine again.
    Any ides on that would also be appreciated. Thanks. Maca
