404 drum brakes
Results 1 to 10 of 10
Thread: 404 drum brakes
    Oct 2005
    Rome
    2,660
    Default 404 drum brakes
    I have a Melbourne built '68 404 sedan with four wheel unassisted drums. I want to replace my rear shoes and have struck a conundrum. The 'brake books' one finds in auto stores say that the brake drums/shoes changed in 1965 and have different brake cyliders,shoes,drums. As we all know, the Aussie made 404s didn't always update at the same time as the French. Now I am aware of the Hydrovac (1965) and Mastervac (1969) mods overseas but of course my '68 has no assistance or booster. Ok, my question is; should I treat my car as a pre 65 model for brake disposables, or should I purchase the shoes that are encompassed within the chassis number parameters in 'the books'?
    Jul 2004
    CLARE SA
    2,324
    Of course it may provide some logistical problems, but could you not use your existing shoes as templates?
    Otherwise, accurate measurements of all critical dimensions might assist.
    It would seem likely that your disposables would be after '65. Order from the book, if they dont fit, exchange them.
    ed ge
    Apr 2003
    385
    Quote Originally Posted by edgedweller
    ed ge
    Would be best to take your shoes to a brake specialist and get them to bond new linings to them or as Edge says they can measure and order in exchange shoes.
    Good luck !
    Apr 2003
    385
    Quote Originally Posted by bahay
    Good luck !
    ANother thought...it's very worthwhile to get your new brake shoes radius ground to match your drums. There are lots of 404's i've seen with poorly contacting rear linings, because they weren't raduised to match the drums..and as the rears take a small bart of the braking load they take a long time to wear in.
    Oct 2005
    Rome
    2,660
    Err, thanks for the suggestion. On a more general level, did 404 brakes in Oz change at all before the advent of boosting? You see, I have a set of (early) rebonded brake shoes (E1280) to put in...
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    387
    you could always pull the brake drum off and have a look
    Pete
    I am gunna get another 403 on the road........one day
    Apr 2003
    385
    Quote Originally Posted by PCOATES505
    Pete
    Yep, PCOATES505, that's the best thing to do. get out the brakes spring pliers and remove the old ones...... from memory I don't think the sedan rear brakes had too many changes other than wheel cylinder bore reduction...to account for boosted later types. The shoes looked remarkably consistent.
    Far North Queensland
    1,494
    Default 404 brake cylinders.
    Quote Originally Posted by 68 404
    Not sure about the brake shoe size. Needed to replace brake cylinders in my 404 at one stage. Dealer told me that my vehicle was"French Motor Show Model" whatever that was and the only available cylinders took a smaller diameter pipe and "nut". I had to make new brake hydraulic lines for the car.
    Paul.
    504-504-504,
    Northern Outpost.
    9,259
    Quote Originally Posted by 504-504-504
    Paul.
    504-504-504,
    Northern Outpost.
    The big rear brakes were fitted from mid 1965.
    All had 1inch cylinders until the disc brake models.
    The earlier cars had 1/4 inch pipes, the later 3/16, this explains the different cylinders.
    The 1968 rear brakes are the same as the disc brake cars except for the cylinders.
    Graham
    Oct 2005
    Rome
    2,660
    Graham
    Thanks for that!
