Peugeot 505 Auto Gearbox Capacity
    Nov 2003
    136
    Default Peugeot 505 Auto Gearbox Capacity
    Anyone here know the transmission fluid capacity of a ZF 4HP22 auto gearbox in a series II 505? Or have the Haynes manual handy? Thanks.
    Philip
    Tadpole Haynes762Extra's Avatar
    Oct 2005
    Australia
    2
    Default 4HP22 capacity
    Quote Originally Posted by R12 Fan
    Philip
    Hi Philip,
    From haynes #762 (505) Page 7 General Dimensions,Weights and Capacities
    Auto transmission drain and refill 4 HP22 2.6 litres or 4.6 pints
    and for information the 3 HP 22 1.6 litres or 2.8 pints
    Cheers the Haynes 762 extra team.
    Sharing the knowledge is a two way street
    12,266
    Philip
    it should say in your handbook but it will be around the 6L mark from dead empty
    if you are changing the oil then you are only going to get around 1.5L out of it anyway
    the only way to change the oil completely is to disconnect the cooling lines and stick the output one into an empty drum and the supply line into the new oil and start the car up and let it pump through untill you get new oil coming out the output side
    beware though as this will take around 20L to do it thoroughly
    the other way is to pull the box out of the car
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Nov 2003
    136
    Thanks for the info guys. I dropped the pan and changed the filter and so far it seems to be running quite well. I didn't realise that there was so much oil locked up in the torque converter. Looks like I'll need to pay to have it flushed professionally some time.
    Philip
