Help...No brakes!!
Results 1 to 11 of 11
    12
    Default Help...No brakes!!
    G'day all
    Got in the s16 this morning and brakes felt a bit spongy. Went to the shops and when i got back in...no brakes, nothing, peddle pushes all the way in with no resistance at all. Brake fluid reservoir has drained, and i didn't get any warning lights on the dash before. What could this be? No fluid on the ground anywhere..has my master cylinder crapped itself?
    Dan
    Jul 2004
    nth balwyn, victoria
    1,428
    well the fluid had to go somewhere.
    check all connections and look at the back of all the wheels for signs of leaks,by the sounds of it it may be leaking while pressing the pedal but not squirting directly on anything so its not leaving tall tale marks.
    look inside at the carpet near the pedals to see if its wet.
    check the haines to see how the system works and go over it to find the leak.
    good luck-BAZZ
    Ipswich, Queensland.
    1,911
    Look at the brake booster wher the master cylinder bolts to it, most likely it will be wet, and so the Master cyl will have to be rekitted, resleeved or replaced. The contact in the on the reservoir float often gets crud on it over many years, not allowing the light to come on when the fluid is down. Could be a brake caliper, but is less likely.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    ‘02 and ‘03 Renault Clios 1.4L
    12
    thanks Bazz
    would it happen quite sudden if it was a slow leak like you suggest? or would the pedal just go spongy when the reservoir eventually empties and air gets in the system? Also anyone know if the brake setup on the s16 is the same as 306 (only haynes i got)?
    Dan
    12
    Default Help...No brakes!! *Update*
    After much pumping of brakes and topping up of reservoir, i have found a great dirty hole in one of the brake pipes towards the rear right hand side brake. Any ideas on how to patch this up temporarily so that i can bleed the brakes etc then drive to the mechanic? Or can i pick up one to fit from the closest dealer?
    Thanks again
    Dan
    Fellow Frogger! Kyle's Avatar
    Sep 2004
    Muswellbrook
    873
    Quote Originally Posted by 1st_time_pug
    Thanks again
    Dan
    Too much pressure to 'patch' it up successfully. Best to remove the brake line, take it to an auto shop and get something suitable to replace it.
    1000+ Posts mr bern's Avatar
    Feb 2003
    Melbourne (or touring)
    1,152
    It'll come as cold comfort to you, I'm sure, Dan, but after snagging my 306's brake lines many times on bush runs following stormy weather, I find that the 206 is a lot tidier underneath in this regard ... just try to stay aware of the exposure any time you catch sight of crud on the road.
    MY15 208GTi
    previously:
    MY10 Sportium HDi6 and 1.6L auto
    MY99 206GTi
    MY96 306XSi auto
    MY02 Clio 1.4L auto
    1ére grenouille:
    MY5? Simca Aronde 90A
    QUICK! MORE BREAD, MORE CIRCUSES!!
    12
    The hole is in one of the metal brake pipes not in the rubber line. It is where the pipe goes around the shock absorber, almost as if it has been rubbing on it..
    Member dom19's Avatar
    Sep 2005
    Lobethal
    87
    You could take it to a dealer & get a new one, but if it was mine i'd take the line off the car & take it to a brake specialist. If they are any good they will make one up for you on the spot. They should be able to reuse your old nuts if they weren't damaged getting them off. It's easier with brake line spanners, they don't round off the nuts so easily.
    Dom
    Member wtpug306's Avatar
    May 2004
    110
    cheers Dom..
    did just that yesterday, replaced it, bled the brakes and away we go. Better than a tow to the mechanics. Thanks for the replies
    Dan
    May 2004
    110
    Hey!!
    <------ thats not me
    Another aussiefrogs person at Deakin, i'll sign you out shall I wtpug306?
