505 SLi wagon rear transmission mount
    Member blizzardboy's Avatar
    73
    Icon5 505 SLi wagon rear transmission mount
    Hi all,
    I would appreciate some advice please.
    I am in the process of putting a replacement 3HP22 into my 1986 505 SLi wagon. I have just loosened off the two 16-mm nylocks that hold the rear transmission mount to the chassis. Unfortunately, the threads are not studs as they are both spinning as I turn the nuts.
    It would appear that I need to get a spanner onto the head of these nuts in order to free the transmission mount. Can someone please guide me as to what I need to open up/remove from inside the car in order to get access to these two bolt heads?
    I working from the Haynes manual.
    Todd
    1986 505 SLi wagon (XN6; 3HP22; silver)
    1984 505 STI sedan (ZDJK; 3HP22; silver light blue)
    Jan 2003
    Campbelltown NSW
    159
    Quote Originally Posted by blizzardboy
    Hi all,
    Todd
    First remove the centre console .
    Then the bolt heads are accessable through holes in the floor down the side of the tunnel under the carpet.
    Tim
    73
    Quote Originally Posted by Tim_K
    Tim
    Thanks Tim.
    Dec 2002
    Menzies Creek
    2,541
    Don't forget that there is a centre bolt as well, from the top, underneath the centre console.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    73
    Default Cheers!
    Thanks Scott,
    I discovered this after a while. Found the 19-mm bolt head under the cowling for the shift lever.
