404 Sofica fan switch question
Results 1 to 2 of 2
    7
    Default 404 Sofica fan switch question
    A bit of a silly question - I've swapped my Sofica fan motor into a new case after the old case cracked. In my haste I didn't note which wires went to which terminal on the three-way switch. It should be a simple trial and error type fix but I just haven't been able to get it to work. If anyone knows the correct wiring I'd be grateful for tips.
    Matt.
    Fellow Frogger! John505's Avatar
    Apr 2005
    Morwell, Victoria, Australia.
    185
    Matt,
    I can't directly answer your query but could you not work it out with a multimeter, and measure the resistances between the various terminals. You ought to be able to determine the "common" contact for connection to either earth or battery.
    Just a thought.
    John505
