205 Speedo Cable Help!
Results 1 to 9 of 9
    Jul 2005
    13
    Default 205 Speedo Cable Help!
    Hi All.
    I own a 93 Si and my speedo has always been a bit jumpy, now it's time to fix it up. Has anybody had to changeover their speedo cable and can tell me whats involved?
    Is this going to be a dash on/dash off sort of affair?
    Member 350manx's Avatar
    Kiewa Valley, North East Victoria.
    100
    Quote Originally Posted by ZAD205
    Hi All.
    Been there done that! Crap job but you don't need to remove the dash but get in behind it from underneath. It's only a crap job because you don't have a lot of room.
    It's been a while but from memory it's a case of undo at speedo and remove the locking rubber 'cotter pin' at the gearbox (or diff?) and remove the cable from there. Insertion I think is speedo first then the bottom but I don't know why I think that! Possibly to ensure the seating of the cable in the speedo.
    Make sure you seal where the cable goes through the firewall (it has a ball arrangement that seals into a cup thingy in the firewall) or you will get some mechanical noise in the car. IT would be good to be Inspector Gadget at these times if you get my drift.
    My speedo wasn't working and I did this and it continued to not work! Turned out to be the little drive gear in the gearbox (diff? - can't remember/visualise).
    David.
    Member stevesteve's Avatar
    Jul 2004
    76
    zad ive got the same problem in my 205 although it doesnt bother me. Im classifying it as giving the car a bit of character
    let everyone know how u get on with it
    May 2002
    642
    As David said there is a plastic gear in the gearbox that the cable attaches to check this first as it can wear and become sloppy causing a jumpy speedo, the second is the replacing the speedo cable easy, well sort of!
    You have to remove the top cowling on the dash to get at the back of the instrument panel, be carefuly undoing and reassembling the dash as the plastic can crack easily.
    Once you get access to the back of the instrument binnacle simply unplug the cable, then pop the bonnet and pull it through the firewall, follow it down to where it joins the gearbox and pull up the rubber boot and "pop" it just unplugs, plug in new cable and feed it back through the grommet in the firewall, make sure the cable is well away from the exhaust, tie-wrap to air-con hoses on the firewall to keep it well away from the exhaust manifold.
    Plug it into the instrument binnacle, rest binnacle and go for short drive down quiet street to make sure it is working, if working re-assemble dash...curse Peugeot engineering have a drink
    05' Megane 225 Cup
    Jul 2005
    328
    Quote Originally Posted by pugsy
    Hey guys, im looking at getting a 205 si with the same prob. Is this plastic gear easy to replace? Im not terribly good with cars through lack of experience, but want to start to do any easy jobs myself.
    Ta
    100
    Quote Originally Posted by scatterbrain
    Ta
    Yep, That's the easy part if you don't mind the grease and crap falling into your eyes as you do it - you're under the car so you will need some stands. There are different sizes (read number of teeth) so make sure you get the correct one.
    100
    That'd be bloody right - I would find the hard way to do it!!
    Jul 2005
    Eastwood, Sydney
    32
    Do you really need to replace the outer casing as well as the inner cable. If you just replace the inner cable you can do it once the instrument binnacle has been removed. I suppose if the plastic gear needs replacing you have to get under the car.
    May 2002
    642
    THe outer casing and inner cable come as one from the Pug dealer... you do not need to replace the plastic gear in the g/box, but it worth checking especially on cars with high k's
    05' Megane 225 Cup
