Limited Slip Diffs
Results 1 to 3 of 3
    Wodonga
    928
    Icon7 Limited Slip Diffs
    Is there any way to tell the difference between a factory LSD and the standard non slippery diffs by external appearances on a 505GTi? I know you can jack it up and spin the wheels etc. but I want to know if there are any external differences.
    Matt.
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Quote Originally Posted by Ralph
    Matt.
    Yes.
    The numbers on the diff housing plate will give you a code for the ratio and type.
    Unfortuneatly I do not have that codeing to hand, (it might be in the owners hand book).
    If the diff is a bit old and tired, the slippery part may not be working to its best, so a jack up and spin may give a wrong result.
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    Fellow Frogger! Jason Morris's Avatar
    Lower Hutt, New Zealand
    126
    Ok, here's my only claim to fame , I posted the diff code pages on this thread...
    505/504 diff interchangeability
    Even the factory LSD (admittedly tightened up - I don't think it was LSD-ing when I took it apart) makes a nice difference in wet weather take off on slippery corners with the PRV...
    Jason
