GTi6 Brakes into a Style
Results 1 to 14 of 14
    Fellow Frogger! mmm...CORNERS's Avatar
    Epping, Sydney
    574
    Default GTi6 Brakes into a Style
    I have a plan bubbling away in my head to get bigger brakes when I need to replace pads and rotors.
    So, simple question: Do the GTi6 Calipers and rotors fit onto the hub of a N5 style? I cant imagine there would be any difference. But can it be Done?
    My guess is that a set of Gti6 calipers second hand would be the go, and just rebuild them. I'm guessing about $300-400?
    Any better Ideas?
    Tristan
    Fellow Frogger! Kyle's Avatar
    Sep 2004
    Muswellbrook
    873
    At a guess the driveshafts are different, so I would assume the hubs are different.
    Master cylinder will be different also.
    Fellow Frogger! WRCPUG's Avatar
    May 2002
    Glen Iris, Melbourne
    1,035
    they should fit.
    the whole knuckle should just bolt up to the calipers and rotors.
    i changed my whole suspension/brakes to gti6 but im pretty sure they are the same mounting points
    standard Xr calipers and strut ib right GTi on left
    PEUGEOT 306 GTi6 (1997-1999 HYBRID)
    105.4kw (141HP) ATW
    2:09 Phillip Island (Toyo Street Tyres)
    2001 YAMAHA YZF-R6
    119HP
    1993 MITSUBISHI 3000GT Twin Turbo
    300BHP
    STOCK-14.006 @97.4mph HEATHCOTE
    STOCK-1:15 CALDER Long Circuit (Stock Street Tyres + Stock Pads :banghead )
    (For Sale)
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,370
    I dont think there will be a big problem. Im putting the 283mm 307 brakes and calipers onto my 205 and they bolt straight on. I am already using a 306 MC so i dont see why they wont fit. I thought the N5 306 shared the same hubs as the GTi6.
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Fellow Frogger! J206GTI's Avatar
    Jun 2003
    BIG Gravel Island
    357
    Quote Originally Posted by mmm...CORNERS
    Any better Ideas?
    Tristan
    isn't it easier to just fit pads with higher friciton co-efficients ?? the minute you put bigger brakes on the weight increases. also if you have ABS you need some serious work done there....
    just make sure you have enough rim clearance as well, you don't want to have a disc bigger than what the rim allows.
    Jason
    Jason
    206 GTI MY01.5 Oversteer Edition
    Myth Buster Logic : red cars go faster !!
    Red Car Bling factor :
    1000+ Posts TroyO's Avatar
    2,511
    Quote Originally Posted by J206GTI
    GTi6 disks and calipers have just enough clearance for the stock 15" alloys.
    Troy.
    Epping, Sydney
    574
    Cool, Thanks for the replies. Clearance shouldnt be an issue. I have some aftermarket 15" rims. The car does not have ABS either, so that simplifies everything.
    I was talking to Paul V about it and the only concern he has is that if the GTi6 caliper uses a larger piston, then the brake balance might be messed up. ie:, less pressure to the front...which would be an issue. He was actually trying to convince me to go to the brembos off the 406 coupe and fit 16''s !!!!!!!
    BTW, the only reason i would get bigger brakes it because i just want to..
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Tristan, you know a lighter car STOPS and handles MUCH better.... do you really use that back seat?? Is a spare really necesary (gti180 owners don't think so), no spare no jack either. Remove that rear carpet too son, no ones in there, hence those seat belts can go too. You don't need any of that trim either and I hear that the rear wiper assembly is overrated. Sedans don't have em, what do you need it for? Since the rear carpet is going why not take the front half out too, and just do with black matts doubel sided to the floor. Then sell the parts for a pair of ultralight weight SAAS race buckets, these will be about 12Kg lighter each & look dam tuff..... I reckon there is about 100Kg to go if your serious about it! which will def improve the cars braking prowes. - Chris
    ps,......now about that dashboard.....
    ... ptui!
    May 2002
    1,035
    how much are they worth?
    105.4kw (141HP) ATW
    2001 YAMAHA YZF-R6
    119HP
    300BHP
    (For Sale)
    7,483
    Brembo on 205/306 - whilst the caliper will fit, getting a disc with the correct offset is almost impossible.
    Epping, Sydney
    574
    Quote Originally Posted by CHRI'S16
    hhhahahaha... If i go an a diet, that'll shave a few more kilos too. Perspex windows, CF bonnet, AC...out the door, Paint...now thats gotta weigh a couple of kilos. Id better stay sober or all this will start to sound like a good idea
    Jun 2002
    3,298
    HA!! , but honestly come on, you can lay abit of carpet over that rear area and have a small shagin-wagon, my old S16 didn't have a roll cage just for track work, it played a vital role in my social activities. - Chris
    ... ptui!
    Member flyNxsi's Avatar
    97
    i was genna fit d8 406 v6 brakes to the fronts,only single piston but bigger than my 2000 xsi. caliper and disk wise aswel. was gena go the brembos but good luck finding them! the offset wasnt a major issue just would have too used 16 inch wheels for the non brembos.
    go too a brake retailer and get them too print you off their sheet that shows peugeot discs specs. then you can figure out for yaself what fits. i did just that. and the calipers fit too my hubs...
    good luck
    i speed up for round abouts,corners and chikanes
    May 2002
    1,035
    Mmmm Nice. How hard is it to fit something like these on a 306?
    http://firesport.ipspace.com/?sectio...=show&id=28885
    105.4kw (141HP) ATW
    2001 YAMAHA YZF-R6
    119HP
    300BHP
    (For Sale)
