Ipod Adaptor for the Gti 180
Results 1 to 12 of 12
    Fellow Frogger! Dr_Pug's Avatar
    548
    Default Ipod Adaptor for the Gti 180
    Wondering if anyone has purchased a ipod bus adaptor for there factory clarion player in the 180. If so can you point me in the right direction.
    I went to strathfield car radios they had ipod bus adaptors for kenwood and alpine only @ $199, they do not stock clarion products.
    04' GTi 180
    Fellow Frogger! mmm...CORNERS's Avatar
    Epping, Sydney
    574
    check ebay. Most likely it will be an adapter that plus in to the stacker control.
    548
    Quote Originally Posted by mmm...CORNERS
    Theres this
    http://caraudiosecurity.com/shop/pro...s_id/4191.html
    Clarion: EA1251E - Clarion I-Pod Adaptor
    It reads
    Tap into the power of portable digital music with the iPod® adapter. Start with any Clarion CE-NET headunit equipped with an IP-Bus connection and use the optional adapter EA1251E to link your iPod to your sound system for -literally - days of your favourite digital music.
    Any one know if the 180 unit is CE-NET equipped, i highly doubt it, perhaps the stacker would be...........
    04' GTi 180
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by blackster
    Any know if the 180 unit is CE-NET equipped, i highly doubt it, perhaps the stacker would be...........
    All I can tell you is that it is a square, blue, 9 pin mini-ISO adapter on the back of the radio. I don't think this is CE-NET, but I have no idea for sure.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    1000+ Posts kermit's Avatar
    Jun 2002
    Inner city, Brisbane
    2,335
    Quote Originally Posted by SLC206
    Correct you are on both counts Simon. Easiest way to add iPod conectivity to the RD3 headunit is by patching into the cd stacker line-in. This has been done by at least one 307 Yahoo member, that I know of.
    Cheers Simon
    >8-]
    Rendezvous Adelaide 2005
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    548
    Quote Originally Posted by kermit
    So the 180 pug clarion head unit is not CE-NET bus compatible, the clarion ipod adapter must be plugged from a clarion stacker?
    04' GTi 180
    Jun 2002
    2,335
    No the iPod is connected without an adapter. It is plugged into the cd stacker line. Headunit is getting a signal from what it thinks is the stacker.
    Cheers Simon
    >8-]
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    548
    Sorry im getting a little confused
    If what im understanding is correct, the pug head unit is CE-NET bus compatible. 9 pin mini-ISO adapter on the back of the pug clarion radio is what the stacker is hooked up to, and it also allows for the clarion ipod adaptor to be hooked into also.
    04' GTi 180
    Epping, Sydney
    574
    Apparently, with a wiring diagram, you can hook anything up to the stacker input. Some of the pins are standard line-in inputs and the other pins are for the controls. ie: skipping tracks. But thats about as much as I know.
    Go get yourself a nice eclipse unit, or a nakamichi with a AUX line in. Or get a simple pioneer unit with an iPod control. Easier, faster, better.
    Jun 2002
    2,335
    The headunit IS NOT CE-NET compatible. The Clarion iPod adaptor isn't needed. The 9 pin mini-ISO adapter for the stacker has a connector spliced into it. This spliced in connector is plugged into the iPod. The headunit thinks it is getting a signal from the stacker but it is coming from the iPod.
    Cheers Simon
    >8-]
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    Jun 2002
    2,335
    Apparently, with a wiring diagram, you can hook anything up to the stacker input. Some of the pins are standard line-in inputs and the other pins are for the controls. ie: skipping tracks. But thats about as much as I know..
    Correct you are.
    But then you loose the stereo remote and dash display. Plus by keeping the standard unit your costs are less and you can build a real sleeper system.
    Cheers Simon
    >8-]
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    Member Griff180's Avatar
    Sep 2004
    Perth
    67
    Few options here. Let me know how you go as I'm thinking of doing the same in the near future.
    206Gti180 cd tuner
    2004 Black 206 GTi 180
