Approach and Departure angles.
Results 1 to 17 of 17
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Default Approach and Departure angles.
    Without a measuring tape (and how does one compensate for spring compression) does anyone know the approach and departure angles for the 206GTi180?
    If the said car was jacked up and the springs chocked at an extended position to get the extra height, will this cause any damage to the car if it is not moved. The ramp angle the vehicle must traverse is about 32deg, and no they can't use other wood or ramps to change the angle.
    Ideas?
    - xTc -
    Now this is a .sig
    Sense Pug307's Avatar
    Australia
    4,355
    This is a spec I've never seen from Peugeot, even in press kits where they tell you the length of wiper blades!
    Other than having it measured, probably best to try and contact someone at PAA.
    Peugeot 307 XS 1.6
    Rendezvous Adelaide 2005
    6,527
    XTC, you might get better help if you said why. It it going on a ferry or car transporter or something?
    2003 PEUGEOT 206 GTi
    XTC
    XTC is offline
    Mar 2003
    8,566
    Quote Originally Posted by Stuey
    Yep, Ship .. hence the loading ramp is not moveable/adjustable, owner concerned the 32degs is too steep and looking at ways of reducing the risk.
    - xTc -
    Now this is a .sig
    16,536
    I just move the my cars height control lever next the seat to 'HIGH', that should clear just about any ramp made anywhere.
    Hope this helps
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    Hope this helps
    Just watch your head on the ceiling, gets a bit bumpy!!
    Dave
    16,536
    Seriously though,
    Do you or a friend have a welder .... Spend the $$$$ and buy some metal and make yourself up a set of ramps with a large departure angle ...
    XTC
    XTC is offline
    Mar 2003
    8,566
    sigh .... I repeat " The ramp angle the vehicle must traverse is about 32deg, and no they can't use other wood or ramps to change the angle."
    - xTc -
    Now this is a .sig
    16,536
    Quote Originally Posted by XTC
    - xTc -
    Aren't you just trying to get a car up onto ramps .... I have a set that a 'dead' hydraulic Citroen can climb ..... If a car with only a few milimeters ground clearance and a 124" wheelbase can get onto the ramps, I assure you, a little poogoe can.
    If you make your own, make the long and low .... It'll be the same as driving up a gentle hill....
    Fellow Frogger! Marc's Avatar
    Jul 2004
    122
    Ive taken my car with a full load before onto a car ferry did it with ease just drive on a angle so the front tyre on one side goes onto the ferry first. Then just keep driving at that angle until your on. I doubt you will have problems, i do it alot and never had a problem.
    16,536
    Gee's I'm slow .... Now I get it, you want to get the car up into a buidling/ship/fixed ramp .....
    I'm sure they have faced this issue before, they probably have a 2 long lengths of wood they lay down for lowered cars to drive up....
    XTC
    XTC is offline
    Mar 2003
    8,566
    I give up ... come back when you've read the ENTIRE thread
    Thanks to others who have bothered to provide valid suggestions.
    - xTc -
    Now this is a .sig
    XTC
    XTC is offline
    Mar 2003
    8,566
    Finally .... YEAH !!!!!!
    They may have faced this situation before, but this ship normally takes TANKS, so ramp angle is set, and they don't usually make exceptions or changes .. you know the armed forces, but if anyone can make a square peg fit in a round hole .. it'll be them.
    - xTc -
    Now this is a .sig
    16,536
    Fnd what else there loading .... Maybe there's a recovery vehicle/tow truck being shipped. All it would need to do is lift the Poogoe by it's front towing points (giving much more overall ground clearance) and TOW in on and off the ship
    XTC
    XTC is offline
    Mar 2003
    8,566
    Fnd what else there loading .... Maybe there's a recovery vehicle/tow truck being shipped. All it would need to do is lift the Poogoe by it's front towing points (giving much more overall ground clearance) and TOW in on and off the ship seeya, Shane L.
    That's the kinda lateral thinking we were after (doubt there will be a tow truck, but could be another truck to put it on first) ... that or he could just trade down to a sh!tron?
    - xTc -
    Now this is a .sig
    anywhere
    2,101
    32 degrees is steep. Getting into four wheel drive territory. As an example my Niva has an approach angle of 40 and departure of 34. Departure will be not much trouble, it will only drag its tail, approach in a fwd is another matter. A lot to damage. Also before lifting it by its nose with the towing hook find out if its frame is made to take this force. Remember people used to loading heavy equipment may not appreciate the subtleties of handling a small car.
    Member Mic_Col's Avatar
    Gold Coast
    85
    If you get to the ramp and find the car is too low at the front and all other plans failed. Perhaps lift the hatch and get a couple of guys to sit in the boot for that initial approach. That will lift the nose quite a bit.
    Once got a commodore out of a hole like that. It's front left wheel was in a hole so deep that the nose was sitting on it's frame, spin the wheel by hand. Opened the boot and we got five guys standing in there, car drove straight out. A Commodore nose weighs a lot more than a pug's.
    From the Family Guy lounge . . .
    BRIAN: Let me get this straight....you're asking if they've ever done an episode of sesame street in which The Count kills somebody....and then drinks their blood for sustanence....
    PETER: Yeah
    BRIAN:
    No, i dont think they've ever done that
