Tyres recomended for 15" GTI rims on 505 GTI?
Results 1 to 10 of 10
    Fellow Frogger! james h's Avatar
    Jan 2005
    Barossa Valley
    170
    Default Tyres recomended for 15" GTI rims on 505 GTI?
    I am after some feedback on what tyres, dimensions and prices anyone reccomends running on the 505 series II 15" mag wheels.
    205,405,505,306
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    Quote Originally Posted by james h
    James, I've got a set of Superlites on my 505 which are 15 x 6". I'm running a set of 195/60/15 Dunlop LM702's and I'm quite happy with them. Go for 205/60/15's to reduce the speedo variation (mine is out by about 5-7%). The Dunlops have lasted at least 35000k's of moderately 'sporty' driving and perform reasonably well in most conditions. They do however get a bit twitchy in the wet, but that's what I wanted, and they're totally predictable.
    PS 205/60/15's make it look a bit angrier too, an added bonus.
    Chris.
    Sorry forgot about the price, about $130 - $140 a piece from memory.
    Jan 2005
    Barossa Valley
    170
    Thanks. will 205/60/15 rub on the front struts?
    205,405,505,306
    Aug 2005
    Athens, Greece
    661
    205's will clear fine, corner and brake better, make the car rev lower at the same speed, and will give a "fuller" look. On the minus side, the car will not be as torquey because of the added weight and larger wheel plus tire radius. I run the 190's on mine but I use it as a dirt racer.
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Yes they might.
    I run the 195/60/15 on the stock GTI mags.
    I use and reccommmend the Mitchelin MXV8s @ $175.
    Good wear, good all round grip in the dry and wet, (not that I have seen much of that recently). I do big miles, on good open roads, (1000km/wk).
    Stick with the factory specs for the tyre size, they work and a mistake is 6-800 Bux worth.
    Alternatively go cheap - bobs threads if all you are doing is around town, (not my bag, but an option).
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    A friend with a GTI has run Dunlop LeMans A5's and more recently Yoko A539's. The Yokohamas were far better than the Dunlops. He runs the standard 195/60R15 (I think)
    Nick
    1983 Peugeot 505 GR
    Member eatpeople04's Avatar
    Apr 2005
    Eltham, Victoria
    116
    I went for the recommended size as well, 195/60 and ended up with Yokohama C drive. About $130 - $150 from memory, and I cannot explain the level of improvement from the (Bridgestone?) Eagles that were on it.
    Excellent grip in wet and dry (struggles to lose traction in the latter, and yes I have tried hard!).
    Haven't got any experience other than those, so may not be very useful to you.
    eatpeople04
    Now showing in:
    "Betty" 1997 Black 306 GTi6
    "Shaggy" 2001 Green Subaru Outback
    The Mrs. Has
    "Wags" 2006 Ash Grey 307 XSE Hdi Touring
    And for floating...
    "Korka" 1978 Red/Blue Ramsay Lynx with 327ci Chevy
    Previously:
    "Cliff the 505th" 1985 White 505 GTi
    "Clive the 505" 1983 Poo Gold? 505 STi RIP
    Hobart
    1,496
    Dont go for 205's they are to baggy on those wheels.
    195/160/15 are PERFECT and yes I think the MXV8's are a pretty good tyre as well! We have them on our GTI and they are very nice
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Jan 2005
    Barossa Valley
    170
    I E-mailed Michelin Australia and asked the same question, and for their recomendations. Recieved no reply, oh well.
    However, thanks for all your replys lads. Appreciated.
    R's James
    205,405,505,306
    Fellow Frogger! boodek's Avatar
    Wodonga, Victoria, Australia
    343
    I'll be after some new tyres soon for my 1990 wagon; it's the family car so I'm not after high performance, I don't want to spend a stack of money and I quite like the look of larger profile rubber. So, I'm thinking of fitting bog-standard 205/65 15" tyres which can be bought for around $100 each for reasonable Dunlop, Bridgestone etc. tyres. They are about 13mm or 2 % larger in diamenter than the originals which isn't major, and would have the added benefit of dropping the revs proportionally, giving slightly better economy. Speedo and odo readings would similarly be out (under) by about 2%, but again not a major problem. Can anyone come up with good reasons why I shouldn't fit 205/65's to my wagon?
    Ben.
    _ _________________ _
    A very fun 1997 manual 406 ST
    A lovely 2006 407 HDi Executive
