MI16 ignition problems
    Aug 2005
    Scotland
    9
    Icon8 MI16 ignition problems
    Help!!!! I've got a 1993 405 MI16 and I cant get a spark out of it.
    I've changed the ignition module, and coil, the wiring looks good and the distributer looks good as well. Anyone any ideas?
    Apr 2002
    Tangalooma
    160
    Icon3
    Quote Originally Posted by Sheps
    I. Sounds like a short or open circuit somewhere start by checking for movement of the needle of a dwell gauge connected to the low tension side of the coil this will tell you if you have a problem with the low voltage of the HT side of the ignition system. Q was the replacement coil fitted a new or known working item????????????? Have both coils checked by a auto electrician! Failing that get them to look at the cars wiring!
    Quality is remembered long after the price is forgotten!
    Aug 2005
    Scotland
    9
    Cheers I'll check for a short circuit. The coil was new aswell.
    Aug 2005
    Scotland
    9
    Cheers for the advice. However I was told to check the crankshaft sensor aswell, and it had been hit by somthing and had a big cut in it!!! Changed that and away she went. Well pleased now!
