504 Starter Motor
Results 1 to 8 of 8
    Fellow Frogger! Peter J's Avatar
    Jul 2003
    Dubbo NSW
    198
    Default 504 Starter Motor
    Hi all,
    I've noticed on a couple of occasions now that the starter motor seems to spin but not engage on the flywheel ... when I try again it will start the motor no worries. Seems some probelm developing. I thought I would ask to try to pre-empt a bigger problem so I won't get stranded anywhere.
    Is it a starter motor problem ... solenoid .... or low battery charge?
    Peter J.
    PJ
    12,269
    Quote Originally Posted by Peter J
    Hi all,
    Peter J.
    sounds like the soleniod is not throwing properly
    is it a du sillier starter ?
    if so it may be worthwhile trying to source a bosch one as they are much cheaper to do and parts can be found anywhere
    on that note though i have a bosch in the 604 that is doing exactly the same as yours and it was rebuilt by the auto spark but i haven't had time to take it back to them
    as far as i am concerned they can take it out and fix it and put it back as it isn't right sans charge as soon as i get some time to do so
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Jul 2003
    Dubbo NSW
    198
    I'll have a look when the sun is out and it's a bit warmer? Cold here now.
    Shocking ain't it when you pay to get something done and it still don't work!!
    Come to think of it I'll check on my spare 504 as well ... I knew I had that sitting there for something.
    Peter J
    PJ
    Member LynCliff's Avatar
    Cohuna Victoria
    94
    Its more likely the Bendix clutch on the drive gear about to fail and the same advice is relevant except I prefer a 505 starter with new brushes and bushes fitted. Almost every 504 Ducellior starter I have had has ended up with Bendix failure but still has done good service up to then,
    LynCliff.
    Jul 2003
    Dubbo NSW
    198
    Quote Originally Posted by LynCliff
    Is the early 505 with XN motor fitted with Bosch or Ducellier starter motor?
    I presume from what you are saying is that it is a Bosch and will slot straight into the 504?
    Peter J.
    PJ
    Cohuna Victoria
    94
    They could be Ducellior or Paris Rone but they are nearly identical to each other but have not seen a Bosch. They do fit straight on to a 504 though and I think work better than the 504 Bosch unit. They crank over faster and seem to handle hot starts better. They have a different design Commutator with Triangle shape brushes and are physicaly shorter than a 504 unit.
    LynCliff
    Jul 2003
    Dubbo NSW
    198
    Both my 504's have Bosch stamped on the solenoid. I cannot see any markings on the starter motor itself. I assume from that they are both Bosch units?
    I will pull one out and get it serviced etc and should be OK from there.
    Peter J.
    PJ
    12,269
    Peter J.
    bosch ones are cheap and easy to get done
    parts are easy to come by
    should cost you around $120 all up to get it overhauled
    1 x 2018 3008
