Manual Box's for the PRV
Results 1 to 15 of 15
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,464
    Default Manual Box's for the PRV
    Just to get my head around all this, what manual box's bolt up to the PRV and associated pug torqure tubs,
    Now the BA10/5 of course does.. Was there a BA10/4sp at all,
    basically ba10/5 are seemingly expencive and or rare, would mind using a 4sp if they be plentiful
    Dec 2002
    Menzies Creek
    2,542
    Quote Originally Posted by bowie
    BA10/5 speeds are very easy to find.
    BA10/4 speeds are very difficult to find.
    What is nearly impossible to find is the correct input shaft and bell housing for either gearbox.
    Having said that, I know a guy with a V6 BA10/5 for sale. Just might take a few $$$ to convince him. Nothing rare is cheap.
    The other problem you'll have is flywheel and clutch setup. A friend of mine works at a performance clutch place, and they have the pattern required to make a flywheel and clutch setup to operate the system. For the really high performance setup, they can even produce (for a price, of course) a flywheel and clutch combination with 4 tonnes clamping pressure from titanium alloy that only weighs 2.8 kgs
    Let me know if you need to be put into contact with either of these people.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Aug 2002
    3,464
    cheers thanks for clearing that up ... Titanium you say Hmmmmmm
    9,290
    Quote Originally Posted by Demannu
    The early 604s had a BA10/4, these were probably the strongest and most reliable box that Peugeot has ever made.
    The V6 rally car that i am involved with has one of these and has not given any trouble despite being caned for four and a half years, to say nothing of the previous 25 years in the donor 604!
    Graham
    Dec 2002
    Menzies Creek
    2,542
    Graham
    Indeed, but how often do you come across a manual 604 (that isn't a diesel)?
    I've only seen one, and there is no way that car is ever going to be wrecked! 40,000kms on the clock and garaged all it's life - looks like it's just come out of the factory.
    BA10/5 speeds were in all of the early 5 speed 505s with XN motors, early 2 litre STI ZEJ motors (didn't make it to Australia), 505 Turbo-Injection (didn't make it to Australia) and all of the turbo-diesel motors. Of these, only the STI box has the same input shaft as the V6, and none of the bell housings are anywhere near close.
    The early V6 BA10/4s and V6 and STi BA10/5s I find are most suited to a modified V6. The later ones are geared a bit too short in first and second.
    Scotty
    9,290
    The 604 it came out of was so rusty that you could pull pieces of metal off the body! No great loss to wreck it although a pity because it was the first 604 in the PCCV in 1977. Its early life in England (1975 to 1977) was no doubt to blame for the rust.
    Graham
    Dec 2002
    Menzies Creek
    2,542
    Graham
    A shame really. Why is it that 604s seem to rust out so much quicker than their 504 and 505 counterparts, anyway? I had an '81 604 that was very rusty just about everywhere, and my '69 504 only has a couple of little spots.
    At least the gearbox went to a good home Graham. Did you get the motor as well? Was there much difference between the UK and Australian spec motors?
    Scotty
    12,269
    i have a UK spec engine here and it is no different from the aus spec
    many have told me there is yet with both pulled apart and checked out i found nothing different between the two
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Dec 2002
    Menzies Creek
    2,542
    So the compression ratio is the same? Camshaft profiles?
    I was led to believe that the UK spec cars didn't have the EGR system or thermostatically operated distributor vacuum advance system that ours did.
    Scotty
    12,269
    the one that i stripped down didn't have the pollution gear but internally it was the same as an aus spec
    this is the reason i went the way i did with the engine i built
    i used the 604 block blored out to suit the 91mm volvo liners and then used the 604 heads with volvo camshafts
    the UK pistons and heads are the same as the aus spec as are the cams
    you can get some nice cams though if you get the GTI cams from a 604 though which i have been thinking of doing but i don't really feel like pulling the heads back off to change them
    1 x 2018 3008
    Dec 2002
    Menzies Creek
    2,542
    You don't need to take the heads off to change the camshafts. But the engine does need to be out of the car, or at least have everything disconnected and drop the crossmember/engine/drivetrain so the heads are clear of the firewall. Otherwise cut a couple of holes in the firewall to pass the camshafts through, then patch them up with a grommet once you're done
    Scotty
    12,269
    true but it's a hell of a job to do them
    i have seen a couple of volvos over the years with holes in the firewall
    1 x 2018 3008
    9,290
    No Pollution gear, air pump etc.
    Actually I preferred the 604 engine to the even fire which replaced it. I had put Volvo ignition and Renault 30 carby and manifold on it.
    The Renault 30 set up gives less power than the Solexes but MUCH better torque and drivability.
    I wish I'd just put a set of rings into this rather than fitting the B280E.
    Graham
    Dec 2002
    Menzies Creek
    2,542
    Graham
    Better in what way? I've heard that if the B280s have standard inlet ports, they don't rev as well. Is this true?
    What engine management are you running on the B280? Standard? Does it use a mass air flow meter?
    Scotty
    9,290
    It just seemed to have more usuable power, it felt bloody quick in third and fourth gears between the trees whereas the even fire, although sounding great just doesn't seem to have it.
    Yes, the torque curve of the 280 drops lke a stone after 5000.
    It has Autronic engine management with MAP sensor.
    Graham
